Question about Refrigerators
Can't find refrigerator coils/ cooling issues
I have a newer GE Freezer top refrigerator. Recently it stopped cooling and freezing and I lost almost everything in the fridge and freezer. Looking at the back the condensor was pretty dirty. I cleaned it real good and cold air started pumping in. I want to clean my coils too, but cannnot find them on this model (GE GTS22kbmbrww). It works pretty good but I have to keep it on full blast (ie. 9) to keep everything frozen. Looking for recommendations. Thanks!
  • 358 Answers
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Posted on Apr 21, 2009
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE SSL27RGRB BS. The freezer stopped freezing all the way when I took off the interior rear panel the bottom coils are working good but the top coils are warm and do not freeze at all. What do I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE side by side Not freezing or cooling at the top levels
heatman101
rtyhrtgf
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top coil is freezing up, the remaing coils are not getting cold.
low on freon or plugged to the point of where the frost stops on the evaporator. Evaporator should fully frost up on all coils...
Sep 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils and water in drain tube frozen
check to see if the fan running first, if yes than you may be losing freon. if not , try a new fan motor
Jul 29, 2008 | GE GTH18KBM Top Freezer Refrigerator
Refrigerators Logo
388 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
