Question about HP LaserJet 3300mfp All-In-One Printer
Only want to feed from the feeder not use the flat bed.
I am using a Hp 3300 Mfp. I'm try to scan a document from the flatbed but it keeps trying to use the feeder i have cleared the feeder and have turned the machine off but no luck. It there a option on the printer??
    President:
  • HP Master
  • 1,996 Answers
I think you have to change the option from the HP solutions center in your computer.
Please see the pdg users guide for your printer available by clicking here for more detailed instructions
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Line down page when using the paper feeder to scan... prints fine directly from the glass
Hi there, Open up the flatbed. You will see to the left side of the glass a small strip of glass.That is the glass the Document Feeder uses when scanning. Just clean it properly because a lot of the times people use tipex or some sort of correction fluid or even wet ink and it gets stuck on the glass creating lines then.
Regards,
Jul 29, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
My feeder to scan puts a line down the entire document - the line doesn't appear when I scan from the deck of the printer. I've attempted to clean the rollers but the line still appears on my document?
You don't say what kind of printer you have.
So, I will generalize my answer.
The reason for the line using the ADF and no line with the flatbed is that the paper is moving when using the ADF. So, a piece of dirt, dust or whatever on the ADF glass will cause a line because the paper is moving over a mark on the glass. The copy made on the flat bed glass doesn't move, so no line.
Anyways, clean the thin piece of glass that should be to the left of the big flat bed glass. That will fix your problem
Jan 20, 2011 | HP Office Equipment & Supplies
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
Copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
ADF Usage
Put the paper in the automatic feeder. In the software options, click on ADF (automatic document feeder) and it will scan multiple pages.
Jun 06, 2008 | HP LaserJet 3030 All-In-One Printer
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
HP LaserJet 3300mfp All-In-One Printer Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
