Double imaging on a sharp small copier
This isn't actually "my" problem, but I have a friend in the business who has trouble with several (3) Sharp AR-168S machines. Evidently they double image on the 1st copy only. If he runs say 10 copies, the 1st one comes out with the double/residual imaging, and the 2nd through tenth come out fine. He has tried replacing the drum, and it didn't make a difference. The problem still existed. If anyone has seen this problem and has a solution, I would greatly appreciate any advice. Thanks.
    Problem Solver:
  • 5 Answers
Check the ereaser lamp if the machine has one
Posted on Oct 05, 2007
  • 24 Answers
Check the drum cleaning blade.if it is ok check the fuser roller.
Posted on Sep 22, 2007
  • Swaroop js Sep 24, 2007
    check the distatnce of this duplicate image from the original one.observe whether it is happening in the diameter of drum or fuser roller. like this you can confirm the problem and replace the same.
I am getting on sharp 5320 copier L6 and E7 codes
L6 - Polygon motor lock detection
E7 01 Duplex model memory error/ Image data error
02 LSU trouble
06 Image data decode error
10 Shading trouble (Black correction)
11 Shading trouble (White correction)
16 Abnormal laser output
F2 02 Toner supply abnormality
Mar 13, 2011 | Sharp AR-5320 Black and White Copier
Double image on the first copy only
try to reset your printer. Turn off, remove the power supply from the socket leave it for 30 mins and turn it on again. try one copy at a time
Sep 21, 2007 | Office Equipment & Supplies
My copier is Sharp ARM420u it displays E7 call for service how do i solve this problem?
02 LSU trouble
Jan 04, 2011 | Sharp AR-5320 Black and White Copier
I Have Sharp Photo Copier AR 5316 when i given Print command the image was good but background double image was also come pls sir give some urgent tips sir
Needs a fuser hot roll. Once the get worn, they pick up some of the image and reprint it on the page.
They are available form several sources, Kaytin comes to mind. Precision roller. Google the printer model number . I would google is like this. Sharp AR 5316 hot roll.
That should give you several sources, Honestly I would replace the press roll also. Probably you should be able to find them both for less than 100 dollars, I sure wouldnt pay more. Look around. You can find them for a decent price. You may even want to look on E-bay. they often have them there.
Aug 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Double imaging on paper
Yes, the toner is not being cleaned off, you will need t change the roller, it can also cause jamming
Jan 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
Nov 14, 2008 | Sharp AR-5316 Advanced Digital Imager...
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
95 people viewed this question
k24674
jasbo
jasbo
