Question about Dryers
Dryer stopped working mid-cycle.
Our dryer just stopped working. It wasn't a "monster" load, but it had a considerable amount of clothes in it when it stopped working (mid-cycle). It was working, my wife opened it to check on the clothes, and then when she closed the door it didn't start again. It's a GE model DBL333EB1WW. Thanks
    Genius:
  • Dryers Master
  • 1,198 Answers
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Posted on Apr 21, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Why does my dryer make a load bang mid cycle?
You are overloading your machine, and in mid-cycle, the clothes are becoming out of balance. Try running the dryer with smaller loads. You will find that the clothes will come out of the dryer with fewer wrinkles, and that your items will be less likely to be damp after a drying cycle. If you continue to overload your machine, you risk breaking of belts or otherwise damaging your machine. You also may decrease the life of the clothes you dry since overloading is also hard on seams and fabrics.
May 11, 2014 | Audio Players & Recorders
I have a AEG L12719VIT. The dryer cycle seems to be overheating or not draining. The clothes are very hot, but still damp. Even when we reduce the load considerably the same thing happens. It pause's...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jul 20, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
GE DSXH43EAWW dryer stopped working mid cycle
unplug it,take it apart and check it out,you could have snapped the belt,there's a belt switch so if the belt breaks the dryer won't start,or if you haven't taken the dryer apart and cleaned it out and also the vent line you could have popped one of the t-stats,only way to tell is by checking them with a meter.the dyer should be cleaned out once a year ,if not the air can't move freely and one of the t-stats will pop as a safety,the dryer will run to hot and take out the thermal fuse or the high limit t-stat,if it's been taking longer to dry the clothes or if you see lint stuck to the bottom of the dryer door these are signs of bad air movement and the dryer and vent line needs to be cleaned out.
Dec 30, 2017 | GE DSXH43EAWW Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer overheats, stops mid-cycle
Hi, Will the dryer restart right away? Sounds like a motor going bad. With a model #, I can get you part#s if you need them. Is this a whirlpool brand?
Let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Dryers
Works on all cycles except that on the Automatic dry Miser setting the dryer stops mid cycle. All other cycles work fine and run through the complete cycle.
Inside the drum is 2 long metal trips that measure capacitance in the clothes as they get dryer. Sometimmes liquid fabric softener gets on them and stops the process. Wipe them off. They are right on the filter housing inside just below the filter.
Feb 20, 2009 | Dryers
Dryers Logo
330 people viewed this question
Top Dryers Experts
