Double image on the first copy only
This isn't actually "my" problem, but I have a friend in the business who has trouble with several (3) Sharp AR-168S machines. Evidently they double image on the 1st copy only. If he runs say 10 copies, the 1st one comes out with the double/residual imaging, and the 2nd through tenth come out fine. He has tried replacing the drum, and it didn't make a difference. The problem still existed. If anyone has seen this problem and has a solution, I would greatly appreciate any advice. Thanks.
  • Anonymous Sep 21, 2007
    I didn't really ask, but I assume he's eliminated all the common causes (fuser/corona'etc.) other than the drum as suspects for the issue, as he's been in the business for almost as long as I. I'll check back with him, but I think we're probably looking at a more discreet cause based on his statement that he's been "ripping his hair out over these machines" for a little while now. So I think we're still looking for a different solution at this point. Thanks though.
    Sergeant:
  • 279 Answers
Well, double images are most commonly caused by the drum - but I see you already replaced that. They could also be caused by the fuser or charger. Has he tried cleaning the charger. Instructions for that are on page 89 of the manual - which you can view here: http://www.sharpusa.com/files/cop_man_AR168S_AR168D.pdf Assuming that doesn't work (which it probably won't, but always try the easy fixes first), he probably needs a new fuser, or possibly a new charger roller. You should be able to tell which by measuring the distance between the first image and the double image, and comparing it to the circumference of each roller. Whichever one matches is the culprit.
Posted on Sep 21, 2007
    Master:
    Sergeant:
  • 461 Answers
Try to reset your printer. Turn off, remove the power supply from the socket leave it for 30 mins and turn it on again. try one copy at a time
SOURCE:
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
How to clear F5 error in Sharp AR-5316E, my technician have already cleaned the glass and all the optics in the scanner including the lamp and the white strips on bottom but still the error remains.
F5 errorContent Copy lamp error
Detail Copy lamp voltage detection error
Cause Power unit trouble, Copy lamp trouble
Inverter trouble, MCU PWB trouble
Check and remedy
Replace the power unit.Check the copy lamp ON with SIM
5-3.
Replace the copy lamp.
Replace the inverter.
Replace the MCU PWB.
Aug 31, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 151 E7-15 error
copy lamp disconnection trouble - copy lamp or cpy lamp drive circuit (inverter PWB) trouble copy lamp disconnection. If lamp does not light when you power up machine, the lamp is burned out or board is bad.
Aug 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
How cAN i UPLOAD PICTURES OF MY CELL PHONE ONTO MY COMPUTER?
DEAR FRIEND,
1.CONNECT YOUR PHONE TO YOUR COMPUTER
2.DOUBLE CLICK THE COMPUTER ICON ON YOUR DESKTOP
3.LOOK FOR THE PHONE'S FILE AND DOUBLE CLICK IT
4.LOOK FOR THE IMAGES FOLDER AND DOUBLE CLICK IT
5.COPY THE IMAGES THAT WANT AND PASTE IT ON THE COMPUTER'S DESKTOP.
Feb 22, 2011 | Samsung SGH 2400 Cellular Phone
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Double imaging (ghost effect) after several normal copies
you can tried to clean the fixing roller or exchange the drum
Oct 26, 2009 | Canon iR 2016i Black and White Copier
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Double imaging on a sharp small copier
Check the drum cleaning blade.if it is ok check the fuser roller.
Sep 21, 2007 | Office Equipment & Supplies
113 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
