Question about Whirlpool Washing Machines
New Whirlpool washer has automatic temp control problems
Brand new Whirlpool WTW5300 washer with automatic temperature control will not let water get above 80 degrees on warm setting. Wash instructions on clothing indicates warm is 104 degrees F. Nine times out of ten so far when set on cool, warm, and hot settings, cold water cycles on and off so quickly that it bangs the inlet hose repeatedly against the wall. This washer is almost identical to the Maytag Centennial.
  • 311 Answers
SOURCE: washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
aasc
  • 1606 Answers
SOURCE: automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Posted on Aug 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Similar Problem on the Kenmore 500 series
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%&&^$
Posted on Oct 01, 2010
  • 298 Answers
SOURCE: I have a kenmore elite H3 washer. The cold water
go to appliancerepairplanet.vstore.ca for a suppot
Posted on Dec 01, 2010
Whirlpool washer wtw5300 rinse water not emptying at all
pull pump see if it is blocked see if you can spin it
Feb 25, 2012 | Whirlpool Washing Machines
Washer went to a spin cycle and would not spin! Has a tank full of water and only hummms: Will not do anything in any cycle? Water pump or something else? WTW5300
I have had a similar problem . It turned out t be an obstruction in the pump. If your gonna get down and dirty with this machine i suggest testing the motor while your there. If that's fine ? Go ahead and check the pump.
Dec 26, 2010 | Whirlpool WTW5300SQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine water not hot enough
This so called "energy saving" ...That's why they build in this nonsense. Some dumbo in some office somewhere just thought it up thinking that will save the energy. I fact ,that way I have to wash same stuff twice because water is not hot enough ...
Apr 07, 2010 | Whirlpool WTW5300SQ Top Load Washer
Hot water comes in cold/cold setting
These machines are designed to have the cold water around 70-75 degrees. If your cold water is colder than that it will automatically mix in hot during the wash cycle to reach that temperature. It all has to do with the optimum temp for proper detergent function.
Eric
Jan 19, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Automatic warm/cold water temperature setting does
Aug 17, 2009 | Kenmore 22422 Top Load Washer
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
Rinse cycle temperature
You may have a problem with your Temp Switch or the Sensor Thermistor.  Very easy to check and fix depending on your technical ability.  Both of these parts are connected off the Automatic Temperature Control Board.
Feb 29, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
