Question about Amana ARS2464B Side by Side Refrigerator
Buzzing noise from back of freezer
I have a 2004 Amana refrigerator with a bottom freezer. There is a loud buzzing noise coming from the back of the freezer. The compressor is not buzzing, the noise is coming from above the back panel within the sealed portion of the freezer. The noise seems to be the loudest below the water intake for the ice machine and toward the center of the fridge. This buzzing can last for 15 - 20 minutes and then it fades away.
    Sergeant:
  • 212 Answers
Need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Posted on Jun 21, 2009
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Freezer buzzing
What you need to do is either tightn the screws on the fan motor or add some washers to the cover to tighten it up. There could be a small crack in the plastic that could be vibrating too. If the noise drives you nuts you can order a replacement cover from the manufacturer. Good luck
Sep 08, 2012 | Amana Refrigerators
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Jan 07, 2009 | Amana ARB1917CSL Bottom Freezer...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ARS2464B Side by Side Refrigerator Logo
1,079 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
