Question about Onkyo HTR500 Receiver
Power will not stay on
Have a Onkyo av reciever HT-R500..manual says "amplifier protection circuitry has been activated".."contact Onkyo"..I seen one solution about blown fuse and opened reciever up and fuse looks ok.
    Novelist:
  • 153 Answers
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
After turned on the power, the unit shuts down immidietly
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
Mar 12, 2015 | Onkyo Ht-r510 5.1 Channel 100 Watt Av...
Av receiver HT-R500 just keeps shutting itself off?
Too much voltage going in the receiver or you have the wrong size fuse in it.
Aug 24, 2012 | Onkyo Audio Players & Recorders
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
This site said it was free - then there is a charge? I am getting a "Protecting" message when I turn on my receiver - then it shuts off....What does this mean and what should I do?
It means the receiver senses excessive heat, or a short at its outputs. Disconnect the speaker wires and see if that helps. If not, get it to a Tech. If it turns on, figure out which speaker path(s) was causing the problem and resolve it.
The manual.
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Power shuts off immediately after power on.
• Amplifier protection circuitry is activated. Remove the power cord from the outlet immediately. Contact your Onkyo service center.
Jan 13, 2011 | Onkyo TX-SR601 Receiver
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
Amp protection circuit has been activated
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Oct 27, 2008 | Onkyo HTR500 Receiver
Onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Aug 06, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
821 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
