Coil Fan?? The fan at the top of my Carrier 38CKB has stopped. Is this a simple replacement, or is there something else I need to consider.
  • Ken Bledsoe May 11, 2010
    Do you have a volt ohm meter?
    Novelist:
  • 189 Answers
Simple enough if you are handy. And if you are knowledgable enough working with 220 volts.
Be carefull. Probably the hardest part will be removing the old fan blade from the motor shaft. they like to rust themselves on.
Good luck....
Posted on Apr 21, 2009
My carrier condenser fan has stopped running.can i just pour water over the coil and use the condenser untile the repairman gets here on friday
Messy - why not just hook up a regular fan and hook it up to the power line that ordinarily powers the condenser fan.and have it do the blowing until the repair person comes out on Friday. The ideal fan is one of those old floor fans that used to blow air in a 360 direction.
Jul 02, 2015 | Carrier 3 Ton Infinity Puron A/c outside...
My 1.5 carrier with remote stops most of the time , indicating fr. Why is it like that .? I have to unplug it again to make it work
http://www.carrier.com.ph/Media/Default/Manuals/icool_manual.pdf
This PDF explains that its a freeze protection safety. Check air filter or freon leak(their words).
So check filter, and also the coil behind the filter may be dirty. Or it may be the fan blade is dirty. Something making the sensor feel a "too cold" temp. And as always it may have a freon leak.
Jun 18, 2015 | Carrier Heating & Cooling
Why is one 30 AMP fuse pair blowing on Carrier Tech 2000 SS AC Unit?
Pull off one of the wires to the fan. If it still blows a fuse the compressor is shorted. If not replace the fan motor.
Jul 03, 2014 | Carrier Heating & Cooling
Furnace stopped blowing cold. 'Stat works, blower works. Went outside, condensing unit fan does not run, motor is excessively hot to the touch. Fan blades spin freely. I pulled the disconnect and...
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Aug 13, 2010 | Carrier 38CKC030 Air Conditioner
Very frequent loud buzzing sound like a motor trying to start
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 11, 2010 | Frigidaire FRT21P5A Top Freezer...
The fan in the frezzer is working but it wont get cold so top and bottom are warm and before it stopped getting cold there was always an ice build up to the point were it would stop the fan
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
heatman101
May 07, 2010 | Frigidaire FRT21P5A Top Freezer...
Forgot the manual to wire carrier fan coil - took care of the thermostat -but need to wire fan coil
Carrier wires are as follow Red black green whiteyellow. R common Black ground Y cool O or orange Reverse valve G fan W heat. The white on the Air handler depending on your electric backup heat has two wires together connected to white. Orange connects to orange on the condenser. Unless you have terminal board the everything is marked. Ruty
Jun 06, 2009 | Carrier Heating & Cooling
1985 carrier unit stopped. all fans spin freely.
Trace wiring out from fan motor back to relay or contactor. On the relay or contactor check with a volt meter and see if you have power to the fan motor. If you don't, you need to check the coil on the relay or contactor and see if you have power on the coil.(24V,120V,230V whatever is marked on the name plate). If there is then replace relay or contactor. if there isn't the control circuit is probably open and it is likely the high pressure control. You will need to locate this and reset it, if it is a manual reset, or it is possible there is another problem
Jan 18, 2009 | ACE -Air 12,000BTU Air Conditioner Free...
Fan not running properly
Probably need a new fan motor, sounds like it is overheating. This can happen if the bearings are too tight. Not something you can fix just replace. Need an amp meter to check the amp draw on the motor
Jun 10, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
