Question about Dishwashers
Upper spray arm came off. does it snap back on
The upper spray arm of a frididaire dishwasher came off. Does it snap back on or does it need to be replaced
  • blueextc3221
    blueextc3221 May 11, 2010
    usually there is a screw and bushing that mount the arm so it can spin freely.
    If you have the exact model # I can look it up and provide you the answer you are looking for.
  • 10,865 Answers
It snaps back on
Posted on Apr 21, 2009
Question relates to an AEG 80860 Favorit Dishwasher pnc 911371032. theb upper spray arm fell off and i have examined it and the central holding device. they do not appear to be damaged but when i tr
1. To remove upper basket spray arm, tilt it down hard.
2. Clean spray arms jets.
3. Place cleaned upper basket spray arm back in position against the connecting piece: press the two together
firmly, until you feel them snap into place.
Dado
Jan 13, 2015 | AEG Dishwashers
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
My dishwasher arms won't sping, but I can turn them by hand
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf.
Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 22, 2011 | Dishwashers
Top spray arm does not spin
The upper spray arm is powered by water from a tube that runs up the back of your machine on the inside. If the connection is not aligned, then the water can't get to the spray arm. My children use to knock mine out of kilter when they loaded the lower section. It's easy to see if the supports are not attached to the upper rack and a simple snap will get them back in place.
It may also be that the spray arm jets are clogged.Depending on the model, the upper spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then remove the arm. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure..
Jul 21, 2011 | KitchenAid Dishwashers
Upper spray arm failure
Easy to solve!
(1) Remove the drawers to give yourself room to work
(a) bottom drawer just comes right out -- but you knew that
(b) Carefully unclip small plastic retainer caps at the ends of the metal "glides" for the top drawer. Then slide the caps out of the glides. Then remove the top drawer.
(2) Unscrew the "gear-like" plastic fitting into whose hole you were sticking your finger when you felt that small cylindrical ring.
(3) Now that you've got access to the ring, the solution is obvious -- use it to snap the upper arm back into the gear-like fitting. When you're done, the arm will rotate freely in the fitting.
(4) Put everything back together and enjoy the fact that you didn't have to pay some yobbo $75 to come to your hous and do this for you!
(HINT: When screwing the gear-like fitting back into place, use the old machinist's trick of pressing gently and screwing backwards until you feel a click. The threads will now be aligned for you to screw things together the right way. If you do not do this, you might experience frustration reattaching fitting -- since the piece it screws onto is spring loaded.)
Dec 06, 2009 | Frigidaire PLD4555RFC Dishwasher
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Frigiaire dishwasher upper spray arm cover came
Okay, it worked! Reach up in the very top (inside) of dishwasher and unscrew the only thing up there that will unscrew. I just used my dishrag (remember righty-tighty and lefty-loosey). Mine had a small white ring laying in the indention that had 2 "teeth" pointing down. I turned the 2 white teeth crosswise to the two gray teeth in the top of my spray arm and it snapped right together. I then screwed the whole thing (with spray arm attached) back to the top of the dishwasher. I didn't have to worry about the above 'one tooth at a time' thing because mine only had 2 'teeth' and snapped back on easily. Yes, it's a little wobbly but it's always been that way. I always try to make sure nothing is hitting it but will be more careful. Good luck with yours. :)
Apr 15, 2009 | Dishwashers
Maytag Quiet Servies 100
Yes remove the arm ,if its the lower arm it un screws,the upper arm snaps on& off.
Jun 03, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
The upper spray arm came off. How to I put it back on?
I realize this problem was in March of 2008 but if in the case someone else needs the solution. The Frigidaire website doesn't list this in there troubleshooting list either.
I had the same problem and let the upper spray arm off for a couple of months. My glasses were not getting cleaned as well so I was rewashing everything by hand. What's the point of that if I have a dishwasher.
On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
From now on be careful what you place on the top rack, if the item is too big it will cause it to snap off again. I know I will :)
Thank god I didn't get a repair man in here for something as minimal as that.
Mar 29, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
Owen Barnes
