Stuck tape in Tascam Porta One
I have a Tascam Porta One I bought new many years ago. I stopped using it several years ago and it sat on a shelf. I wanted to start using it again to transfer my tapes to my computer, but when I put a tape in, the tape heads moved in the way they are supposed to when I hit play, but nothing else happened, and now the heads won't retract so I can remove the tape. Any suggestions would be greatly appreciated! Thank you in advance for any help you can provide.
Sincerely,
Tosty
  • Dave Tosty
    Dave Tosty Apr 26, 2009
    Mgueffroy, Thank you for the help. I'll see if I can dismantle it and take a look. I'm not sure if I will be able to though with the tape stuck in there.
    Tosty
    President:
  • 1,138 Answers
It sounds like the rubber belt drive may have broken and tangeled in the drive mechanism. If you are confident you can disassemble it far enough to see if thats what happened. You can still obtain replacement belts. If not from Tascam, then try a good electronics store. Take the belt in and they can help you match it up. Thers also a possibility that your pause mechanism id stuck.
Posted on Apr 25, 2009
  • 4 Answers
I have a Porta one, works like a champ, I also work with Orange Sound of South Hadley owned by Greg Dwinell, a Tascam Service center for all the east coast.
Your problem sounds like the drive belt dried out and broke, (same has happened to me). Simple solution is open it up and check the belt. Tascam belts are still available, call Greg @ Stuck tape in Tascam Porta One - cb_transparent_l.gifus.gifspace.gStuck tape in Tascam Porta One - space.gif=arrow.gifspace.gifStuck tape in Tascam Porta One - space.gif"http://i.fixya.net/uploads/images/space.gifStuck tape in Tascam Porta One - space.giface.gif" class="h_mi" />space.gifspace.gifspace.gif413-533-0900cb_transparent_r.gif
In the interim, use the small rubber band from u'r newspaper (acts just as well as a belt) to hold u over.
Best Regards, Steve, MarSayHarrington Associates (413) 533-9972
Posted on Dec 16, 2009
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Were can i get my tascam porta 4 track fixed in herefordshire
These unit are long past their life expectancy and I do work on them and get them going but I am located near Chicago, IL USA.
Generally they need cleaning, lubrication and some new belts.
Jan 25, 2013 | Tascam Porta 05, Porta One & Two Belt Kit,...
Tape heads are stuck will not disengage. transport will rew and fast forward but will not play or record. also could not eject tape. unit is a tascam porta one mini studio.
There is a cam system in the transport and they need to be lubricated. It might cost more than $100 to fix. Sometimes the gears have rounded off teeth that you can not get anymore.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
How do you eject a tape from a Tascam Porta Two ministudio? It's a quite dated model, yet there is no eject button.
This type of model does not have an eject button as the deck is designed so that when the head is retracted as in stop mode you simply pick up the door and pick the tape out of the well. This is pretty much the same in all the lower end Porta Studio models.
Jul 01, 2011 | Tascam Audio Players & Recorders
I require a service manual for a Porta 02
Well you may follow the link below to get your service manual -
http://cgi.ebay.com/TASCAM-Porta-02-REPAIR-SERVICE-MANUAL-/120539404478
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Office Equipment & Supplies
Hi, My TASCAM DA-20 mkII DAT recorder is holding onto a tape. It will play the tape and there are no error messages, but the tape will not eject. How do I get the tape out without breaking the DAT...
A Technician usually has to get a tape out of a machine when this happens. In radio when I was Chief Engineer for several stations in Chicago I would send my defective decks to Russ at New Jersey Factory Service in Emerson NJ. He knows how to fix these units.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 31, 2010 | Tascam Audio Players & Recorders
I have an ACDELCO 6500 Watt Electric Start Generator. i bought it brand new about 1 year ago and it started up with no problems. Unfortunately I did not drain the gas after using it and it sat idle with...
Fuel will go stale if left for a long time. Drain and clean fuel tank and also drop float bowl on carburettor to remove any old fuel. If there is any sediment in the float bowl a carby clean could also be necessary.
Aug 24, 2010 | BUFFALO ACDelco 6500 Watt Generator...
Need tascam porta 07 manual
Havent find the porta 07, most simmilar I think is porta02. I suggest to go to the http://www.tascam.com and and look in right corner in same line with the menu (under- legacy products). When you choose the product an image will came. Go to the RESOURCES tab to get the manual.
This site has a service manual for 17$:
http://www.bonanzle.com/items/search?item_search_page[only_title]=0&item_search_page[search_term]=SERVICE+MANUAL+TASCAM
Aug 06, 2010 | Audio Players & Recorders
929 people viewed this question
 Grubhead
Grubhead
