Question about Toshiba Satellite P35-S611 Notebook
Toshiba laptop fan
I like to swap the P35-S611 FANS WITH NEW ONES, HOW CAN I OPEN THE BOX? THANKS
There is more to it than that, if you just remove the screws on the bottom , youll crack the case... first remove the battery, ram and hard disk., and wifi card. then just above the keyboard, theres a strip of plastic about 1.25 inches wide that spans the whole bottom of the screen... pry this up and put it to the side. then remove the screws holding the keyboard down. remove the keyboard being careful not to damage the cable. now remove the screws holding the screen down(top and bottom of case). unplug the screen and put it in a safe place. now remove all the screws on the bottom of the laptop, MAKE SURE YOU TAKE THE 2 BOLT/NUT/SCREW THINGS OFF THE VGA OUT PORT ON THE BACK! it should be fairly easy to get the top of the case off now. leaving you with the mainboard sitting in the bottom of the case. Now flip over your board, it may take a little maneuvering to get the board out of the case. be careful not to bend the board too far. be careful not to damage the buttons on your PCM CIA card slots. You may have to bend the case a bit to get the VGA ot port out of the case. Now look at the screw locations on the fans. the screws are on the opposite side of the board. unplug fans, and swap them out. now put it all back together! NOTE: if you get several beeps and or blank screen after trying to startup, you probably didnt discharge the static from your body before touching the RAM and it could be either burnt out or you may have to take one of the sticks out and let it sit for awhile.
P.S. if youre replacing the fans because it overheats... its probably not the fans! its the heatsink which requires taking it apart anyhow, but where the fans blow through the heatsink lots of crud gets built up in there and blowing compressed air into it usually does not help. if you do all this, be careful taking the heatsink off the board! and dont damage your chip! if you take heatsink off and chip pulls out with it, youll have to remove chip from heatsink as it is a ZIF socket and dont forget to replace the silver heat compound on the chip! i found it was helpful to pull the heatsink off and run it under some hot water, then dry it with your wifes blowdryer, use some compressed air and q tips to clean your fans out really nice (dont take them apart, theyll never work again) and reassemble.. presto! like new!.. any questions?> give me a holler!
Posted on Nov 09, 2007
    Sergeant:
  • 457 Answers
Remove all the screws underneath first then gently seperate.
Posted on Sep 21, 2007
SOURCE:
P35-611 shuts down while plugged in but not while on battery
using a multi-purpose duster spray can seems to have solved this for me. i dusted the keyboard and a few other areas(carefully) with a q-tip. i wasn't able to fully open my laptop but i sprayed and q-tipped a little on the inside(i couldn't get to the fan which supposedly gathers the most dust) and when i feel the computer getting too warm,i'll spray the keyboard and the back of the computer and my computer ,which was shutting down **** near constantly, hasn't spontaneously shut down since,and i took out the battery. if your problem is dust,this might be at least a partial solution. if you need to take your laptop apart,there are videos on youtube,although like i say i wasn't able to take my p35-s611 all the way apart without possibly damaging the machine.
Oct 22, 2011 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
May 17, 2010 | Toshiba Satellite P35-S611 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me [email protected] i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
I had tried propping it up and setting fans to blow on it and that helped some. But then I stumbled on the answer that has kept me problem free ever since: doubling my RAM. My fans no longer run all the time like they used to, it never since had the dreaded "shut-off" problem and it is fast again - like it was out of the box.
Feb 16, 2008 | Toshiba Satellite P35-S611 Notebook
Missing P35-S611 Restore CDROM
Sorry but that would be illegal :(
Contact microsoft for a replacement.
Jan 05, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611 Notebook Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
