RESET THE PWOER TO THE MODEM ON WHICH FUNCTION KEY
Need to know how to reset the power to the modem on a gateway m series
    Problem Solver:
  • 19 Answers
Power to all internal peripherals is cut when the system is shut down. If for some odd reason your modem is holding a charge, you can unseat it from the motherboard and reconnect it before rebooting. If you explain more in detail, I may be able to fix your problem.
Posted on Apr 21, 2009
Problem with gateway modem.Power light is red wireless light is green,Dsl and Ethernet lights are not on.I have turned everything off and back on.I have disconnected everything and put it back.Nothing...
You need to hard reset the modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
You need to access the gui or firmware of your modem. If it ask for username and password. This is the time you need to contact your ISP. They will help you to configure the modem. Once they provided you the username and password ofr your modem. Write it down so you will have a copy and in case it happen again you know what to do. Username and password for the modem is different from the username and password for your internet. You also need to enter the username and password for the internet so you can use the internet. If you get a red light for the internet, that means the username and password is incorrect.
Mar 07, 2010 | 2wire (1000-000057-000) Modem
2WIRE Modem reset needed
Reset needed.
Go in the gateway address .
eg 192.168.1.254/mdc
type in the password to access
2wire is the password.
Scroll down to troubleshooting on the left, find for resets , click it, it will bring u to a couple of resets. Click the last one - which is reset to factory default. Your gateway will reset - power light changes to orange - and it will reboot. All ur configurations will be lost and u need to reconfigure it back. Any help further this, post it at fix ya :)
Aug 03, 2009 | 2wire (1000-000057-000) Modem
Cannot ping to default gateway
now u need to reset it .
Check in back side of your modem u find 1 reset button press it for 10 seconds then it reset to factory defaults.then u cana cces it with 192.168.1.1
or 192.168.0.1
May 05, 2009 | Computers & Internet
I can not find the PIN number for the router. It
Hi there... I dont get wat you mean by PIN... Is it WEP key your refering too? Well as you said it is supposedly the 10 digits on the modem.. If your unable to connect, then the possibilities are that the modems default wep key has been changed. To reset this key you will have to access the gateway thru
192.168.1.254 or gateway.2wire.net - click on wireless settings and from there scroll down and you will be able to see the buttons where it is marked as use default encryption key or use custom key passphrase. Click on use default encrpytion key , scroll down and click save settings. Now note at this point of time when you click save , whichever wireless devices which were or could connect to the modem when it was in " use custom key passphrase" cant be connected anymore. All the devices must be reconfigured to the default wep key which can be found on your modem which is a 10 digit n numbers.
2nd choice.
You access the modems gateway page to reset the whole modem to factory default
Go to the http://gateway.2wire.net/mdc and you will be prompted for password. By default its 2wire. Once you have accesses in it, scroll down till you see Troubleshooting - then you can see resets. click on it and at the bottom you will see a radio button RESET - Resets your 2wire gateway to factory default. CLick on the reset, your modems power light will change to orange led after 3 secs from your click. and the orange led will be there for ard 10-15 secs. And your modem will boot back. And now its factory default. You need to do the necessary configurations depending on your ISP.
3rd choice
Reset button behind modem
Click the red reset button behind the modem and hold for 15 secs, the modem will be restored to factory default.
Pls note : I will not hold responsibility if any mishaps happens during this operation. All the above is done on YOUR SOLE RESPONSIBILITY. Thank you.
May 02, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
Zyxel 600 series modem set up to phone line
You just have to perform a hard reset on the modem to erase any previous data stored. Locate the small pinhole for the reset button on the bottom of the modem box if it is not at the back. Then you need to access modem gateway to put all configuration information on modem software by typing in 192.168.0.1 in your IE browser's GO TO website box (where you type website address/URL)
NOTE: Make sure that you know your username and password for your current internet connection configuration before RESETTING modem. If you don't have this settings, call your internet provider. =)
Thanks.
Jan 02, 2009 | Zyxel PRESTIGE 645M-A1 (91-004-233005)...
Hi, I purchased Thomson TG585 v7 ADSL2+ Modem/Gateway yesterday and I imported old modem configuration to it and immediately it stops responding. Cannot reset to factory defaults (by reset button too) or...
With the unit powered on perform hard reset back to factory settings. Use a paper clip to push the reset button on the back panel of the modem. Hold down for five to 10 seconds. Release when the power light goes red
Oct 02, 2017 | Computers & Internet
Cannot reset to factory defaults Thomson TG585
You need press the reset button at least 15 seconds
Dec 25, 2008 | Computers & Internet
I hv 2 wire modem bought from my friend, I don't know how to reset user ID and password in this modem
you can try resetting the modem by picking a small pin and pocking in behund the modem which states "reset"
Or if you can access the gateway you can reset it from there.
to access gateway in case type in your browser -- > http://gateway.2wire.net/mdc - <-- you will be prompted to enter password . The default password is 2wire . Once you entered in , scroll down to Troubleshooting which will be on your left
, search for resets <--- Click on it, it will direct you to a page where you can reboot system and stuffs.. Click on the button RESET beside factory defaults. Your modem will be reset to factory default, your power light will change orange and be normal back for about 10 secs ... When everything has come back to normal, you can then continue to enter your user id and password to log in internet.Or alternatively u can Go to http://gateway.2wire.net/setup <--- and configure your modem from there with a step by step guide :)
THANKS
Dec 02, 2008 | 2wire (1000-000057-000) Modem
ATT has given me a 2 Wire Gateway... which does not work
Try to reset the modem from the bottom of it.. press and hold it down for 15 seconds.. check the status of the lights on the power... try to do that and lemme know.. if not you might have to get in touch with the att tech support.
was i help ful?
Nov 18, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
