Question about ViewSonic VX910 19" LCD Monitor
Viewsonic vx 910
Constant flashing screen from normal display to black every 2-3 secs. 3 yrs old
  • halevn Dec 05, 2007
    I have the same problem, using LCD VA912b, almost 1 year old.
    The power cord connect to wallet cord (not to the read of mainboard)
    the power led sometimes blink, and i can not see any (the lcd is being
    black). the power led is flashing, on and off, on and off.....
    I have to turn off the computer, turn off monitor power cord. wait
    about 20 minutes, then turn on again, it will work, but if I turn off
    monitor then turn on, or restart the computer. the power led will blink
    again :(
    Can you help me?
  • shaunc11 Feb 07, 2008
    I have exactly the same problem
    President:
  • 2,022 Answers
It is power problem pls show it service personnel
Posted on Sep 24, 2007
SOURCE:
My viewsonic VA912b goes thru a few minutes of a cycle upon turning on or waking up where it has a black screen, then a few seconds of normal display, then 10-15 sec of black, then a few seconds of normal,...
Look for bad caps as shown in my pictures, common problem in all brands of LCD monitors.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA912B/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Computers & Internet
Vx 2245wm "almost" Black screen
craigcorbin, Could be "switch-mode-power-supply"/CCFL "INVERTER" supply that is flakey or better still has a "thermal" problem. Thermal problems arise from temperature cycling of the parts on the circuit board that heat-up due to their need to dissapate energy in the form of heat, and then return to room temp when unit is turned off. Hot = expand, cold=contract After enough cycles occur on an already poorly soldered connection you will end up with a Thermally Intermittant connection which will only get worse due to oxidation of the now exposed RAW METALS to the surounding atmosphere. Sombody will need to open unit and inspect the board(s) for this type of fault. 12fixlouie
Dec 17, 2009 | ViewSonic Computers & Internet
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
Malfunctioning monitor (BenQ)
hi, first run the system in safe mode, if that works than u will have to look in for driver problems/settings, sometimes uninstalling the monitor & display driver then reinstalling it back will change the settings to default, try it, let me know
Dec 30, 2007 | BenQ FP72G+ 17" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
205 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
