Question about NetGear RangeMax NEXT WNR834B Wireless Router
I cannot reconnect my wireless router back to my computer
I am playing online games with my PS3 and wii. my console tells me no network is detected.
  • 854 Answers
A. Determining the IP Address and MAC Address of you PS3 & Wii:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports (Call PS3 tech support & Wii support to ask for the port numbers to be registered onto the router):
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Apr 25, 2009
I can't play online ps3 games
it could be what type of router are you using? Are you able to sign into the playstation network? You could try setting up a static ip address on your ps3 and setting it as a dmz server. This will open up all ports for your ps3 and should enable you to play games. It should be a workaround for upnp. If you tell me what router make and model your using i can tell you how to do this.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not connect to play online
Well, it could be one of a few things.
On your computer in your network settings, ensure your network discovery is turned on.
When you go to set it up on your PS3, make sure that you have all passwords required to get into your network.
If you manually configure your settings, open your command prompt and type: ipconfig/all this will tell you all of your settings and IP addresses.
If it's an older router, make sure it's within a 10-15ft range so the system can recognize it. If you need to get a new router, some will tell you to get a wireless G for gaming; I got a wireless N brand new (Belink) for $60 and it works way better than the wireless G one I had.
If all else fails, reinstall your router on your computer and leave everything on default except for maybe a password to access the network. When you go into your PS3 settings, let it configure it automatically and just put the password in when prompted.
Good luck and if I've helped you please give me a good rating.
Respectfully,
Don
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 in one room and my computer and internet in another. I have bought a wireless router but it is hooked up in the room with the computer. I don't want to have to run a cable to the other end of...
Check your wireless network name in your computer if it is wireless enabled.
Then go to your PS3. Go into the network settings and check if the wireless connection is detected.
When you check the network settings, make sure that ip and dns settings are set to automatic.
After that you would need to open some ports on the comp for your PS3 so that you can play online.
Also let us know the make and model no of your router so that we could tell how to open the ports on the router GUI.
Very first thing your PS3 should detect the wireless connection on it.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
The connection to the playstation network fails
sounds like a problem with the wireless network card.
Go thru these instructions to get your ps3 to recognize your wireless router, if it doesn't work then you know that your wireless network card in the ps3 is bad:
http://www.ehow.com/how_2291028_connect-wireless-internet-playstation.html
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Connection problem for ps3 internet
cant you attach the old wireless router to one of the expansion slots in the new wireless router and have the old one for ps3 only and the new one for everything else
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
make sure all ports are open on the router
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
How do i reset our wireless network setting on my playstation 3?
On the back or side of your router their is a button that resets it to the original factory settings. Hold that button down for 5 or more seconds then release it.
Everything should be back to normal, also you will have to reconfigure that router
On the bottom of the router the user name as password might be------> user= Admin Pass=password
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
151 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
