Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
The door won't open or close without excessive force.
I checked the trouble-shooting guide, and determined that the lock is "off". It feels like something is dragging on top of drawer. I'm stumped! I wanted to call a certified repairman, but my grlfriend's really excited about this method. Go ahead...make me look bad!
  • 784 Answers
Feeling like going to the bump when closing the drawer because the sagging rubber seal from the top lid pressing again the top groove of your inner tube when closed.
Theis syntoms needs to be addressed since it is very near for a coming problem: Leaking then the Unit doesn't funtion any more.
Why
either the seal is out of its place to press again the groove, or there is a problem with actuators causing the top lid sagging down. It is also possible that the Top Lid is falling out of its snapped position from left and/or right arm unless it unproperly installed if there is a recent service.
are you still excited. Let me know the progress so I can help you out. You can look on my solution on similar problem to get an idea what need to be involved. Good luck in finding.
Posted on Jul 05, 2009
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
2006 Honda Odyssey electric door won't close
there is a slide door control module for each door
Jan 28, 2013 | 2006 Honda Odyssey Touring
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer MDBH940aww...the door is very hard to closed, it seems that you need to force the door close for the latch to lock.. The plastic door latch mounted on the dish washer is making contact wiith the...
Either someone bent the door by excessive weight on it while open (like a kid standing on it) or something is jammed in the sealing surface.
Jun 01, 2011 | Maytag Dishwashers
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
lid is in a locked state.
Door Unlock Failure F-83
retracting.
unlocked state.
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My fixed garage door opener opens fine, but only closes if it is held down. My remote garage door openers do not work at all. I replaced the sensors and they appear to work fine. I tried to reprogram the...
If the sensor is working right, that leaves the downward force sensor tripping. First check for track obstrucions by manually moving the door with the lift disengaged. If door works without excessive force, then increase the force sensor of the lift a bit.
Jun 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
169 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
