Question about Dryers
Is there a rataining clip to hold the idler arm in place.
  • Scorp448 Apr 21, 2009
    Could you give me an idea as to where the clip is located.
    I have replaced both roller wheels in the back and both drum guides in the front but it is still making a nise when it starts and stops.
    I have ordered the idler arm and wheel I just need to know where the clip is located, cause it seems like the old arm is kind of sloppy.
  • 700 Answers
Yes theres a c-clip to hold it on
Posted on Apr 21, 2009
  • Todd Born
    Todd Born Apr 21, 2009
    it should be right by the inner part of the pulley
Replaceidlerarm
didnt specify vehicle -generic answer -jack up vehicle and place safety stands some vehicles need to remove wheel and possible lower valance remove link bolt and with a fork separate arm from center link than unbolt from frame
Replacing Bad Idler Arm Tips for replacing the idler arm on your chevy truck or SUV Idler Arm Replace Diagnose Idler Arm
Aug 26, 2016 | Miscellaneous
Model 5030D
Instructions
Unplug the electrical cord of the dryer from the electrical outlet before attempting to fit a new belt on the dryer.
Remove the lint screen from under the lint screen cover and locate the screws that are underneath the cover.
Unfasten the screws with a screwdriver and remove them from the lint filter slot, setting the screws aside.
Place a putty knife between the top and the cabinet on both sides of the dryer near the front, lifting up to dislodge the lid from the plastic clips that hold the top down.
5
Flip the top back toward the back of the dryer and let it rest against the back wall.
6
Locate the front kick panel and slide the putty knife just behind both sides of the panel, pulling forward to unfasten the panel from the plastic clips. Move the panel out of the way.
7
Locate the screws that hold the front panel on the dryer cabinet at the top on the inside of the cabinet. Remove the screws using a screwdriver.
8
Unfasten the electrical wire connector by hand, pulling it straight out from the back of the front panel. Move the panel out of the way.
9
Place a couple of wood blocks under the front of the dryer drum to support it while you are removing the old belt. The drum is the cylinder that holds the clothes as they are drying, located just behind the front panels.
10
Push the idler arm forward just a bit to relieve the tension on the belt, and slide the belt off the idler and motor pulleys. The idler arm is located next to the motor near the back of the dryer and has a pulley on a metal arm with a tension spring attached to it.
11
Lift the drum up off the blocks just a bit, slide the old belt off of the drum, and take it out of the dryer cabinet.
12
Hold the drum up just enough to slide the new dryer belt around the drum and fit the belt into the V-slot in the center of the drum, laying the remainder of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
13
Loop the end of the belt around the idler pulley and over the motor pulley, pushing back on the idler pulley to release the tension on the belt.
14
Let the idler pulley move back into place and check the alignment on the belt to verify that it is seated properly on the drum and the pulleys.
15
Remove the wood blocks from under the drum when the new belt is installed and attach the front kick panel to the dryer cabinet, pressing the panel onto the plastic clips.
16
Place the front panel over the kick panel and attach the electrical wire connector to the back of the panel by hand, pressing the connector back over the electrical prongs on the back of the panel.
17
Attach the screws at the top of the front panel on the inside of the cabinet with a screwdriver. Lower the top of the dryer back down over the cabinet.
18
Press the top of the dryer down over the plastic clips until the lid is secure and fasten the screws on the inside of the lint filter cover.
19
Slide the lint filter into the lint filter slot and plug the electrical cord of the dryer into the electrical outlet.
Jan 09, 2013 | Hoover Dryers
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
    Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    Need to replace a wiper motor on a 2002 chrysler town and country mini van. how is this done?
    Remove the wiper arms (pop off the caps at the base) and the 15mm nut. Take out the screws that hold down the wind shield cowl lift it away to expose the washer hoses. Unplug the wiper motor (center driver's side) by pulling out the red clip on it and squeezing the tab. Remove the 13mm nut from the wiper motor idler arm and take out the 3 10mm bolts that hold it in place. Squeeze it out from under the wiper transmission, or loosen the lower bolts. You'll see them. Not a difficult job, just take your time.
    Hope I've helped.
    Mar 06, 2010 | 2002 Chrysler Town & Country
    Replacing windshield wiper motor
    Remove the wiper arms. Take out the screws that hold down the wind shield cowl. Unplug the wiper motor (center driver's side) by pulling out the red clip on it and squeezing the tab. (Mark which arm came off which side) remove the 13mm nut from the wiper motor idler arm and take out the 3 10mm bolts that hold it in.
    Feb 23, 2010 | 1998 Plymouth Voyager
    Idler spring came off when belt broke, not sure correct placement for spring and idler pulley
    Takes patients but can be done. First place idler arm in position then connect spring. Try and hold firmly while you place belt through pulley and fold around motor shaft. If installed right ,the pulley will maintain a constant pressure on the belt.
    Sep 27, 2009 | Maytag PYE2300AY Electric Dryer
    Need pitman arm replaced and idler arm replaced
    The idler isn't bad, Remove cotter pin going through the nut, take off nut, you need a seperator tool to pull apart the arm from the center link, once that is done, remove the two bolts holding it to the frame, remove arm, installation is just reverse.
    The pitman arm is a little more to it. Do the same, remove cotter pin, take off nut, and seperate it from the rod, now there is big nut holding it on to the bottom of the steering box, take that nut off (some are a real pain), you will need a pitman arm puller to get it off. Note the position of the arm, need to put new one in same place, pull it off slow, sometimes seals will come with it, put seals back in same way, if they come out. Put some grease on splined shaft, tap new arm on until you can get nut on, tighten up with nut. Hopefully you have any problems. Good luck.
    Mar 24, 2009 | 1997 GMC Jimmy
    Hoover self propelled U6630900 idler arm lock
    Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
    Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
    Broken tumbler belt
    Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
    Jan 03, 2008 | Frigidaire FDE336RE Dryer
    Dryers Logo
    37 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
