Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Engin backfires and cuts out when hot
After mowing for an hour or so the engin would loose power and begine cutting out. after setting for a short time it would start back up .
  • 246 Answers
Hello:
>>From your Description it Sounds like a Bad Ign Module or Ign Coil.
>>Replcace the Ign Module/Coil.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
Cutting out really bad
Hi, Kristy would help me a lot if I knew the year-make-model and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cutting out and back fire while riding
Major missing backfiring cutting out when hot
Cutting Out BackFire when getting on throttle XR250 400
Engine cutting out while riding backfiring when get it to start up again...
Apr 23, 2016 | Motorcycles
I have a ford cvh 1600 what backfire through carborator only when it is hot and then lose its power
Ford Escort carb backfire Questions & Answers - Fixya
www.fixya.com > Forum > Tags > carb backfire > Cars & Trucks > Ford
Ford Escort cars & trucks carb backfire questions and answers. ... Backfire throughcarborator and engine stopped upon returning from store. ... Turbo conversion from 1995 on a CVH engine - engine cuts out ... I have a xr3 ford escort 1600 with a weber carb,itbackfires and spits fuel up Clean the Carburator completely.
I have a xr3 ford escort 1600 with a weber carb,it backfires ...
www.fixya.com/cars/t10838117-xr3_ford_escort_1600_weber_carb
Nov 17, 2011 - I have a xr3 ford escort 1600 with a weber carb,it backfires and spits fuel up ... Turbo conversion from 1995 on a CVH engine - engine cuts out.
All comments on Ford Escort CVH Straight-through exhaust ...
https://www.youtube.com/all_comments?v=1yA5blCpTLM
Jan 05, 2016 | Ford Cars & Trucks
A Ryder 155 after 20 mlnutes of mowing engine cuts off try to start backfires let set overnight start and same case
Husqvarna 155? Sounds like the fuel shutoff solenoid on the bottom of the carburetor is toast! I'd say replace it BUT in the long run, you're better off at replacing the whole carb assy.
Oct 07, 2015 | Garden
Snapper mower
valves overheating needs valve job as mover over heats its looses power until it shuts down
Aug 24, 2014 | Snapper Garden
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
My Briggs and Stratton powered (17.5hp Intek model 311777) Troy Bilt riding mower idled down slowly and died. It was a very hot day after about an hour of mowing. I don't appear to be getting an
Hi, armature is for spark and you stator is only for charging the battery. Check for spark again after disconnecting the single small wire from the armature incase its a safety switch issue, regards Phil.
Jun 06, 2012 | Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
My tzr 250 is backfiring. after backfiring the engine will cut off. and i can hardly start the engine.
A back fire like that can mean an electrical problem.
have the coils checked
it could also be as simple as a short in the cut out switch, or a worn ignition switch
May 25, 2011 | 1992 Yamaha TZR 250 R
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
Plus minus 20kms engine begins to backfire and
You might have a bad fuel injector.
Jul 06, 2009 | 1998 Jeep Cherokee
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
544 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
