Question about Dynex 4-Port 10 Mbps Ethernet Hub
Xbox 360 and computer connection.
I connected the xbox and computer ethernet cable to the hub and only the computer connection worked. Do I need a different IP and DNS code for the hub?
    Novelist:
  • 153 Answers
No you do not. What you need to do is go into the xbox settings and turn on networking. It's kinda buried but it's in there.
Posted on Apr 22, 2009
Bad xbox 360 connection
You have two options to improve connectivity:
1) Move your XBox closer to the router. If you are connecting wirelessly, move your XBox as close as possible to your router. The farther away they are, the slower your connection speed.
2) Purchase an ethernet cable and plug it in. An ethernet cable can connect to your router and be plugged into the back of your XBox. This is the best way to utilize as much juice as possible from your router and get you the connection speeds you need to play online. Ethernet cables run about $20 depending on the length and quality, but its a great investment if you are doing a lot of online gaming.
Hope that helps!
Dec 12, 2011 | Microsoft Xbox 360 Console
My son wants to play against his sister but can't find anywhere that lets her enter the game?
Both have to have xbox 360. Both have to have the ethernet cable attached to each other. (This is called a system link)
  1. Make sure you have the necessary supplies needed for System Linking (all supplies list at the bottom).
    System Link cable or an Ethernet Hub.
  2. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9503394424+9665908481+9016233241+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  3. 2Make sure that all of the Xboxes that will be used are hooked up to different TVs.
    1. 3
    2. To connect two Xboxes, use a System Link Cable and insert one end of the cable into the Ethernet adapter of one of the Xbox consoles and the other end into the other console's Ethernet adapter.
    3. If you are using two Xbox 360s, you can use a standard RJ-45 Ethernet cable instead of the System Link cable.
    1. 4Connect them each into an Ethernet Hub or Switch. A router will also work.
    2. 5Turn each console on and load a copy of the game into each console.
    Oct 27, 2010 | Microsoft Xbox 360 Console
    How do i connect xbox 360 to internet i will be connecting by ethernet,what do i need to do many thanks dave.
    HI Dave ...
    If you dont have the manual, you can get one online from the Xbox site.
    All you need is an ethernet cable and a router port ( where your PC gets its innernet connect.
    Nov 04, 2009 | Microsoft Xbox 360 Console
    How to hook your xbox360 to laptop to get on xbox live
    wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
    Oct 25, 2009 | Microsoft Xbox 360 Console
    Xbox won't connect to live through my laptop
    When you connect the laptop to the router are you using a network cable?
    When you connect two computers such as your laptop and the xbox using a network cable you need a crossover cable not a standard network cable.
    If you use a network hub you can connect two or more computers together using the standard network cables.
    Jul 28, 2009 | Microsoft Wireless Network Adapter Xbox...
    Dynex 4 port hub xbox 360 IP address error
    Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
    Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
    Do i really need Xbox live???
    Hey supcom296,
    If you are looking to connect two XBox consoles together for offline play, the method can vary depending on the type of XBox you own.
    For the original XBox, there should be two supported methods. The first allows you to directly connect two XBox consoles together using a "system link" or Cat 5 Ethernet crossover cable, while the second is to connect up to four XBox consoles using standard networking cables and an Ethernet hub.
    With the XBox 360, there should be three methods available. The first is to directly connect the two consoles using a traditional Ethernet cable (RJ45), the second allows up to 16 different XBox 360's to connect by using standard networking cables and an Ethernet hub, while the third uses either a wireless router or the XBox's built-in Ad-Hoc networking tools to make a connection.
    If you are unsure how to set up the consoles using any of these methods, you should be able to find step-by-step instructions in the owner's manual for your XBox, or by simply visiting the support section of Microsoft's homepage.
    Hope this helps you out.
    Sincerely,
    Aaron
    Go Ahead. Use Us.
    May 27, 2008 | Microsoft Xbox Console
    Xbox 360 pro
    Salutations LHmom,
    Because your using laptop computers and a mobile carrier for your internet services this will be a little harder then normal but not imposable.
    First what you would need is a ethernet switch or hub. This should allow you use the laptop with the Verizon card as a "Gateway". You would then connect the Xbox 360 to the hub and it would share the internet from the laptop.
    Windows XP, and Vista have nice networking wizards that can walk you through the settings. But be aware you may need to change the settings back when you are not using the Xbox 360.
    Hope this helps.
    Jon
    Go Ahead. Use Us.
    May 08, 2008 | Microsoft Xbox 360 Console
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Xbox to compter
    Path #1:
    if you want to play online, with other people i am assuming? then what you would want is xbox live. you do have to setup a stable internet connection in order to connect to the internet*. and also you do have to pay a membership fee in order to stay in xbox live.
    * and if you want to connect xbox live, you need a cable or dsl connection, either you need an ethernet cable or a pre-tuned wireless usb that is made only for the xbox 360. and also, you would need a cable/dsl company that is accepted by xbox live. and then go to the xbox 360 dashboard, then, click "join membership",
    Path #2:
    setup an ethernet connection either directly, or with a router/hub, then go the system settings, and click, "computers" and then click connect. but this path way is only to create a connection to the computer.
    Jan 07, 2008 | Microsoft Xbox 360 Console
    Dynex 4-Port 10 Mbps Ethernet Hub Logo
    333 people viewed this question
    Top Dynex Computers & Internet Experts
    Prashant M
    Prashant M
    micky dee
    Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
