Question about Polyview V17E 17" LCD Flat Panel Monitor
Lcd screen is not displaying anything .other thing like sound are coming properly but it not displaying anything.
    President:
  • 2,022 Answers
Pls check your rgb data cable connection or try to reduce the resolution. bye
Posted on Sep 24, 2007
SOURCE:
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
The screen is white with sound
IF YOUR SOUND IS COMING THRU FOR THE PROPER CHANNEL YOU ARE TRYING TO SEE, THEN THE PICTURE IS COMING THRU ALSO, BUT IS NOT DISPLAYING ON THE SCREEN.
THIS MEANS YOU HAVE A TV PROBLEM INTERNAL IN THE SET AND WILL NEED A TV SERVICE REPAIR TO FIX IT. - SORRY
Feb 20, 2011 | Sharp LC26SB24U 26 in. LCD TV/DVD Combo
Screen will not come on but it will power up
Check to make sure your LCD display cable is seated properly. If it is and you still don't see anything, it's time to replace your LCD.
(You do not need to replace the lid or inner bezel. ONLY the LCD display. This can range between $100 to even $400 to replace depending on your brand and monitor size.)
Good luck, and thank you for visiting FixYa.
Feb 24, 2010 | Everex StepNote XT5000T Notebook
Replaced Display on Vostro 1400, now it's light/fading in areas
Sounds like the connections are either loose or not properly connnected.
Checke the connectors again, and make sure you're not bending any pins in the process.
Jun 16, 2009 | IBM ThinkPad R51 Notebook
Apple cinima display problem
have u updated the drivers, i assume u only took the screen in and they linked it up to there macs,
sounds like a driver issue, try an update,
actionman
Feb 26, 2009 | Apple Cinema Display Flat Panel Monitor...
Janome 6500
You may have a loose connection to the screen, and it may also be that the screen has gone out. Here's a link to another Fixya expert that sells the screens, it has her email address, she may be able to help you fix the problem or get you a new screen. Try contacting her for assistance.
Aug 08, 2008 | Janome Memory Craft 9000 Computerized...
LCD display is blank
Has the camera been dropped? If the camera appears to work properly and you can download the pictures to a PC ok, then it sounds like your LCD display has failed.
I have replaced several of these screens on Kodak cameras. If the camera is under warranty, you may be able to get it repaired free of charge, provided there is no evidence of abuse.
You can order the screen directly from the parts department of the manufacture and attempt to replace it yourself but I would only suggest doing that if you feel confident in doing so.
I wrote an article on how to replace a damged LCD screen.
http://www.fixya.com/support/r370257-replace_defective_lcd_screen_in_kodak
Please let me know if I can be of further assistance to you.
- Jim
Feb 21, 2008 | Canon PowerShot S3 IS Digital Camera
Problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Amptron CMV-922D 19" Monitor
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Polyview V17E 17" LCD Flat Panel Monitor Logo
81 people viewed this question
Top Polyview Computers & Internet Experts
Ekse
Alun Cox
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
