Question about kawasaki Full Suspension Mountain Bike Men
Kfx knocking i bought a kfx 700 it knocks it is not coming from bottom end it sounds like it is in the head could it be a valve spring or what
    Novelist:
  • 104 Answers
Sure! You could be hearing from a broken spring, but it could also need a valve adjustment. If it runs ok, with all its usual power, I would take it to a shop and get their opinion on the valve train. Try putting a cheap stethoscope on your ears and pinpointing the noise if you're not sure where it's coming from. Thanks, hope you get it fixed. TT
Posted on Apr 21, 2009
4200 chev knock but not arod
Could be piston or piston land knock pull plug wires or coil wire plug if diffent coils find out if thr knock changes sounds as you connect fireing plug wire on and off thus killing spark to individual cylinders you will jear tje sound if its on a cylinder. In paryicular to note .once found then decide to examine why also the main bearing end play may allow the crankshaft to movr forward too far if worn out or worn on crank cheek the last think is tapered rod thhrow causes a knock when particulare cylinder fires do the spark test uses ears to determine..all old chevy V8s whithe mechanical fuel pumps with push rods had a knock you could hear dam easy okay take a toilet plunger handle off plunger put one enf om motor while its rumning then put your ear om the other end listen to valve cover thrn by the intake near head move up and down engine then listen on bottom of oil sump pan you can find oit where noise is loudest the remove something to check whats really wrong good luck
Jan 08, 2017 | Cars & Trucks
I put my kfx700 in time on the rear cylender and it is blowing back through the carb
if you jumped time or broke the chain then it sounds like a bent intake valve. you'll have to take the head off to straighten it.
Dec 24, 2016 | kawasaki 2004 KFX 700 V Force
How to time a kfx 700.2006p
if it broke the timing chain it might've bent the valve
Dec 24, 2016 | kawasaki 2006 KFX 700
O4 kawasaki 700 kfx v force firing on one cylinder
Hi, Adrian for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
rear cylinder not firing
How to Troubleshoot Kawasaki 700 Force eHow
Kawasaki KFX 700 Backfiring Follow up Is it Fixed
http://vitek.vellum.cz/manualy/Kawasaki%20KFX700%20V-Force%202003%20Service%20Manual.pdf
May 26, 2016 | kawasaki Motorcycles
I have 2005 kawasaki kfx 700 it will not start when cold.It don't matter if you choke it or not.If you crack the throttle just a little bit it sounds like it is trying to start.I replaced the fuel pum
Trying changing the plug , if you didn't already see what type of condition it's in. Check to make sure you have spark. It may be your air screw need tunning.
Sep 02, 2014 | kawasaki 2005 KFX 700
Can I fit valve stem seals without taking the head off on 1600 sentra 1997
No you can't..
Fitting valve stem seals involves removing the valve springs. This means the valve has to be held in place by a valve spring compressor (bought from almost any spares outlet). The springs are compressed by placing one end of the compressor tool on the valve face and the other end over the spring cap, then squeezing the tool to compress the spring, then removing the split collets that hold the spring in place, removing the spring cap and spring, then eventually you have access to the stem seals.
The head has to be removed to accomplish all this.
Mar 28, 2014 | 1997 Nissan Sentra
94 cavalier top end knock
From your description of the knocking, mileage, and oil crusted on the intake valves you need an engine or a complete rebuild of the original.
Apr 21, 2013 | 1994 Chevrolet Cavalier
Ticking ford focus
You need to be certain that the intake manifold is completely free of parts/remnants of the "old" valve seat that shattered. If you do not clean and blow out the intake manifold with compressed air before installing in on the new head, chunks of the old seat can and likely will find their way back into the combustion chamber.
Jul 23, 2012 | 2001 Ford Focus
Engine making a loud knocking sound
is the loud knocking sound coming from the top section, or the bottom section of the engine, if it's from the bottom, it could be a connecting rod, that is going bad, also if it's from the top of the engine, could be in the rocker arm assembley, this is where your valve spring, rockers, and retainers, and tips of valves are located, also have someone to see if the knock sensor is bad, normally , these are located not to far from the crankshaft pulley up from the bottom of engine.
Mar 22, 2011 | 1995 Mercury Grand Marquis
Popping or knocking heard in front end when riding
Sounds like the Spring may be broken or there is another loose front end part such as a ball joint or a spring seat or something like that.
I had a broken spring on my 1990 Cadillac Deville and didn't know it until looking at it up under the wheel, and experiencing a popping or knocking sound when turning.
It could also be the bearing cap area problem.
May 12, 2010 | 1998 Cadillac DeVille
kawasaki Full Suspension Mountain Bike Men Logo
165 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
