SOURCE: Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
SOURCE: Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
SOURCE: Auto focus problem
Well, if all the software is ok, maybe the button is damaged and not able to give the two modes any more. If the camera has done it´s fair share of pictures, maybe it needs some repairs... since you´re the first that I personaly have heard is in this situation.
Mechanical things get broken more easily than we want, I guess. I´d recommend a repair shop for your camera and let us know how you ended up, please.
SOURCE: When half press the shutter
Yeah,why did you half press the shutter?When you take a photo,you should press the shutter with force quickly.I think you didn't set your Panasonic Lumix DMC-FZ5 Camera at a proper mode for the scene,shot with a correct the next time.Wish helpful to you.
SOURCE: Panasonic Lumix digital camera DMC-F27
Hello
That is a sign of lens problem. Try gently - moderate tapping the camera repeatedly, with the lens facing the ground.
