Question about Samsung SyncMaster 173V 17" Flat Panel LCD Monitor
Monitor defect - Menu will not disappeard...
Hi...I have problem im my Samsung monitor, that was When I Switch on my System, the Menu (monitor pop-up menu(that contains color,brightness,degauss,contrast and so on)) will not disappeard..It will not invisible...Still it will stand in center of the monitor....pls send me the suitable query for this defect....
    Problem Solver:
  • 19 Answers
Your probelm si made by menu keyboard (one or more of the micro switches is defective) so you have to change them or cable that interconects keyboard and main board is damaged.
Good luck.
Posted on Jan 17, 2008
SOURCE:
Hi, i have a samsung b1930n monitor. It's menu
My monitor is getting blank within 3 seconds after I start my system what could be the problem
Jul 09, 2011 | Samsung Monitors/LCD LCD Panel
My brightness menu will not go away
Does the brightness keep increasing / decreasing or only the menu remains on ? If it keeps increasing / decreasing, that particular switch must be defective. Need to replace the switch. Samir
Mar 21, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor settings
Well yes you can reset your monitor, you need to completely switch off the monitor (means switch off your monitor from the main power not only using the on/off button) leave switch off your monitor for 24+ hours and check again, this procedure is known as hard reset...... Please post comments if further you have the same problem........
Good Luck!!
Thanks
Mar 02, 2010 | Acer AL1916W 19" LCD Monitor
I need a a SAMSUNG monitor driver ( SyncMaster 753s)
You do not need to install any driver to use this monitor. The operating system has built-in drivers for this monitor
Apr 30, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Feb 22, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Monitor control lock
press 14second menu switch..then show unloked,and check 5volt regulater ic Lm7805..
Jan 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Control locked
try pressing the buttons (with your monitor turned off) if they have allowances for switching (if it is a push button then each should be pressed slightly and you should feel that it switches through!) if you pressed it and felt hard ( like something was stuck) then the buttons might have misalligned from the switches on the board. do not open your monitor unless you have electronic servicing experience. other causes might be the monitor's sync. processing IC. it could be defective.
Nov 15, 2007 | Samsung 793S 17" CRT Monitor
Open Questions:
See all Samsung SyncMaster 173V 17" Flat Panel LCD Monitor Questions
Samsung SyncMaster 173V 17" Flat Panel LCD Monitor Logo
257 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
