Question about HP LaserJet 1300n Printer
Worn out teflon coated roller
The roller seen from the opening in the back of the case has lost its teflon coating and doesn't feed. What is it called, so I can order a replacement?
'Fuser" rollers are often teflon covered aluminum rollers, but in the case of an HP1300, it is a "fuser film" wrapped around a heating element -which enables the "instant on". You can google it , or find them on ebay.
Posted on Apr 21, 2009
Print is repeating on next page
That type of problem is usually caused by the fuser assembly. The heat roller is coated with a Teflon film. When this coating get worn down some of the toner stays on the fuser and is deposited on the next page. You will need to replace the fuser assembly to correct the problem. The part number is RM1-4728 They are available from Ebay. It does take a bit of time to install one and you will need the service manual to do it.
Apr 01, 2013 | HP LaserJet M1522nf Multifunction Printer...
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jan 22, 2013 | HP LaserJet 2420 Printer
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
Our HP Laserjet P4015N is printing funny. When printing out a column of information, it will continue to print the information above it, in the white space below the column of numbers in a grey tone. I...
Hell
The "ghost print" you are getting is caused the fuser, even with 60% life left. We have seen this type of wear pattern happen if you print more on one side of the page than the other, or print darker images than standard use would be. The fuser heat roller is coated with Teflon to prevent the toner from sticking to it but when the coating gets worn down you get the ghosting like you have. You can replace just the fuser or you can get the whole maintenance kit and just keep the pickup rollers for later use. If you open the back of your printer so you can see the fuser you should be able to see the heat roller and most likely you will notice a worn area that is not the same color as the rest of the roller.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP LaserJet P4015N Printer
We had a paper jam and I got the paper out but now the fax machine is printing out pages that are smeared with black toner
The fusing unit heat roller is damaged or worn out and it needs to be replaced.The roller has non-sticking teflon coating.When this coating is bad,toner start sticking to it and causing jams and bad copy quality.
Sep 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Samsung ML-1710 Printer - see below
Try to put new cartridge in.If this doesn't fix the problem, it can be that the fusing unit heater roller teflon coating is worn out and this roller needs to be replaced.
Apr 28, 2009 | Samsung ML 1710 Laser Printer
A 1/4" vertical gray line off center prints on copies and faxes
chances are that its coming from your heat roller. if you open rear cover and look closely, you will see a unit with an orange colored lower roller, and the upper one is your heat roller. if you inspect upper roller, you should see the defect. its a teflon coated roller and sounds like teflon has worn off. you will have to have that replaced.
hth,
razors
Apr 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Copies have ghost image
yes. although I would first check the fuser unit. It is located the exit side of the copier. let the copier cool down before handaling the teflon fuser roller. The upper roller has a teflon coating, if it is worn the image will not transfer properly to the paper thus leaving a duplicate / ghost image. Good luck
Nov 24, 2008 | Office Equipment & Supplies
Print rubs off paper on toshiba 4550 copier
the teflon coating on the fuser heat roller has worn off and you need to replace the upper fuser roller.
Oct 06, 2008 | Office Equipment & Supplies
Paper jam
very well could be,
1-if the plastic over the lower fuser is wrinkled torn or missing it will cause jams
2-if the top fuser roller is losing it's teflon coat also
when you do replace the roler/s change the claws also.
Aug 27, 2008 | Toshiba e-Studio 232 Black and White...
HP LaserJet 1300n Printer Logo
159 people viewed this question
Seeker5211
Seeker5211
