Question about Canon i860 InkJet Photo Printer
Too much green
Printer does not print right color; too much green. Done all maintenance routine. In nozzle check printout, the last big rectangle is green instead of grey as it use to be.
  • yvonchev Apr 23, 2009
    Seems that the problem started after I ran out of Magenta (I didn't get the low ink warning for some reason...) I put a new cartridge in a week ago, did many head cleaning passes. All the cartridge are in the right position, I'm the only user. You wil find attached a jpeg picture of the nozzle check. What does it tell you?
  • yvonchev Apr 26, 2009
    The replaced cartidge was a Magenta photo. I learned that it's not somethig to do. Replacing it by the correct Magenta, correct the problem.
    Tanks for the tip.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Printing too green is a sign of low or no Magenta ink. Might pay to look there. (Green is Cyan and Yellow ink, so Magenta is missing to make Grey/Black)
Sounds like someone might have also managed to mix up an ink cartridge and put it in the wrong slot?
Check that the nozzle patterns for each colour are in the right place on the print out according to the sample in the manual / online. Maybe Magenta is missing altogether?
Posted on Apr 21, 2009
How do I run cleaning option -- won't print
Select something to print. Then go to FILE - PRINT and when the dialogue box appears, click to right of named printer on PROPERTIES. Then when that dialogue box appears, click on the MAINTENANCE tab and you can then click on Head Cleaning. Just make sure there is at least one sheet of A4 office-type paper in the printer, as when the clean has finished, you need to click on Nozzle Check. The printout will show if the nozzles are now working. Never do more than a couple of such cleans and always follow with the Nozzle Check printout - you can turn the paper round to use a fresh part - it only uses a small part of the paper each time.
Jul 17, 2015 | Epson Stylus Photo R1800 InkJet Printer
My printer only prints black
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 08, 2013 | Konica Minolta MAGICOLOR 7300EN LASERPR...
Canon mx860 printer not using ink from PGBK 220
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
We are trying to get our iP90 printer to print. We have cleaned the print head, replaced both black & color ink. We have done a deep cleaning several times, cleaned with alchol & cotton q-tip....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 04, 2011 | Canon PIXMA iP90 Mobile Printer
How do I print the nozzle check pattern?
Dear Sir,
plz flow this step for solve your probelm
These are the 2 important features for maintenance of your printer.
Nozzle Check
If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
1. Click Start
2. Click Control Panel
3. Click Printers and Faxes
4. Right click your printer icon
5. Click Printing Preference
6. Click Maintenance
7. Click Nozzle Check
8. Click Print
9. Click Finish (if the nozzle pattern is perfect) OR
10.Click Clean (if the nozzle pattern breaks at certain places)
The following is the sample of good nozzle pattern and a bad nozzle pattern:
Good nozzle pattern:
Bad nozzle pattern (Head Cleaning needed):
Head Cleaning
Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
1. Click Start
7. Click Head Cleaning
8. Click Start
9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Stylus printing striped alternating shades of yellow and green of image
Possible printhead issue.
Please reseat the black cartridge. Let the printer charge like it normally does.
Print a nozzle check pattern. If you see gaps, missing lines or missing colors on the pattern, clean the printhead using the driver. 3 consecutive cleaning cycle is recommended. Compare the nozzle pattern over the last printout. If you see any improvement, you can clean the head numerous times until you get a perfect nozzle check pattern.
Apr 30, 2009 | Epson Stylus C86 InkJet Printer
Printer is producing too dark and purple shaded output. I believe this has to do with nozzle jet function but there is no information on how to reset the nozzles on the basis of the colour printout. It's...
Are you trying to print
1). photgraphs in colour
2). Photographs in B&W
or
2). plain text
In canon iP4000, you can do a Nozzle check by going to the maintenance.
Go to print anything from a word file or an excel file > in the print box > go to Properties> go to Maintenance.
Here you can do Cleaning, Deep Cleaning, Print head Alignment and Nozzle check.
If your Nozzle check matches the check pattern(this you will find once the Nozzle Check gives a print), then it possible that either the right paper is not put in or your master could be very dark. Alternatively you could reduce the print setting to Standard...
Let me know if the above solves your problem..if not we can do some more trouble shooting.
Mar 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
Printing Problem
Click the maintenance printer icon below right corner click right , click nozzle , printer will print for / you can determine what problem of the printer , black color there are spaces , magenta also spaces ,blue some spaces , and yllow sometime none. This mean your printer head are need to clean , after cleaning , nozzle check again yuo can see the big defference.
Dec 18, 2007 | Epson Stylus C46 InkJet Printer
Canon i860 InkJet Photo Printer Logo
312 people viewed this question
old marine
old marine
