Question about Cell Phones
4pr909 bluetooth headset chargine issue
I bought this headset today and it says when it's charging the red indicator light is supposed to come on. I have pluged and unpluged both the the cable from the wall and a usb port to no avail as well as dissconecting the cable from the headset. I know this is a cheap headset I only wanted it to play my ps3 and all it says ub the manual is to keep unplugging it any suggestions?
I have the same problem i even went and bought a second one script and this one does the same problem thing is there a customer care care phone number
Posted on Mar 29, 2012
  • 40 Answers
It may be defective. Even if its not charging well it should still light up if there's a charge connection. Return it if you can and buy a better one.
Posted on Apr 21, 2009
I just bought th hv 800 bluetooth headset, when i
might indicate it is fully charged already .
Sep 23, 2014 | Radio Communications
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
May 19, 2010 | Motorola Mobility H700 Wireless Headset
4pr909 bluetooth headset passcode won't work with samsung juke
had same problem with this headset on two phones and finally solved it.
1. make sure bluetooth on phone is activated (know that sounds silly but some people forget)
2. with the headset turned off, press and hold the on/off button on the headset until the light on the headset FLASHES CONTINUOUS BLUE AND RED (about 8 seconds). This is most important, because if lights on headset are not continuously flashing blue and red, the headset is not in discovery mode.
3. once headset is in discovery mode, go into "my devices" on bluetooth menu on phone and click to search for new devices. make sure phone and headset are close together. phone will say searching- BE PATIENT, THIS STEP TAKES THE PHONE SOME TIME. eventually phone will show that it found your headset.
4. once the phone lists the headset, click on the headset and tell the phone to connect to the device. at this point the phone will bring up a passcode screen. enter 0000, and tell it to connect. when it connects, the lights on the headset will automatically go to an intermittent blue. you should be all set.
the biggest mistakes my kids made trying to pair these headsets were:
1. failing to turn bluetooth on for the phone
2. turning the headset on in something other than discovery mode (continuous blue/red flashing lights)
3. not being patient enough to wait for the phone to find the device.
hope this helps
Dec 21, 2008 | Cell Phones
Cell Phones Logo
472 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
