Question about Dell Dimension 8400 PC Desktop
Start up will not retain memory for fire wall setting.
Most often (not always) when I turn on my Dell Dimention 8400 computer, I have to go to the control panel and click the box for my microsoft fire wall to be activated. Why will it not hold the memory to keep the fire wall active?
    President:
  • Dell Master
  • 1,996 Answers
Make sure you haven't installed a third-party internet security suite that includes a firewall. You should only use one firewall on your system and some third party firewalls automatically turn the windows firewall off. But your security center should show that you are protected by a firewall, nevertheless.
This behavior can be an indication of malware installed on your computer...
I recommend you go to windows update and make sure you are current with all critical security updates for your system, then go to www.malwarebytes.com and install their AntiMalware software. Scan your system and fix any problems it detects.
Then see if your system retains the firewall settings.
I thought there was a MS knowledge base article on this that had something to do with sp3 and a bug fix but I can;t seem to find it right now...
If I locate it I'll post back with a comment...
In the meantime, if those first two suggestions don't turn anything up, I'd run chkdsk on your system and see if it finds some file corruption.
See this article and this one
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
I have a Dell 8400 with a wired keyboard and wireless mouse. My computer went into Save Mode and my flatscreen monitor says to press any key on the keyboard or move the mouse to restart. When I do this...
try shutting down, remove power cable, remove memory chips, remove battery on motherboard(coin battery). remove grpahics card from slot(if its the kind you can remove). Now wait 10-15 sec then put in the graphics card, the batter, the memory sticks and close the case plug in the power cable and see if this works!
Jun 12, 2010 | Dell Dimension 8400 PC Desktop
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
I have no display when computer is turned on and
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 13, 2010 | Dell Dimension 8400 PC Desktop
How do I replace low battery in dell dimention 8400
The Dell Dimension 8400 has a CR2032 battery inside the case. If your computer is saying that it is dead when you turn it on, this is a quick fix. A new CR2032 battery can be purchased from any general store (Best Buy, Walmart, Radio Shack) for about $4. Open your Computers case. There are buttons at the top and bottom that let it open like a book. You will see the battery somewhere on the main board. It looks like this. Use your finger nail or a pen to push the clip holding it in place out of the way. Replace with you new battery and close everything up.
Feb 20, 2010 | Computers & Internet
Sonic, Dell Dimension 8400, Philips DVD +- RW burner
are you copying ,copy writed material?then you need dvd descripter.
Jun 14, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 beeps 6 times monitor dosen't turn on
Below is a link to the beep and light codes for a Dimension 8400. Check your codes and reply back if you need further assistance.
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm
Jun 03, 2009 | Dell Dimension 8400 PC Desktop
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
