Question about Sony PlayStation 2 (PS2) Console
ANALOG STICK intenrnally broke
My ps2's rite analog stick internally detached or broke or it moved from its origin.........so my problem is HOW THE HECK DO U FIX IT COZ I NEED A SOLUTION plz.........**when i push the analog stick at any direction it won't cum back 2 centre.**
    Problem Solver:
  • 13 Answers
You could try to dissasemble it carefully and see if it the stick has simply just become dislodged but it sounds more like something has broken inside the housing, Possibly just as easy to buy a replacement if you can be bothered to repair it, There not overly expensive nowdays.
Posted on Sep 22, 2007
SOURCE:
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
The left analogue stick keeps moving the character around even when im not doing anything
Hello alsupjonatha,
Aug 07, 2011 | Microsoft Xbox 360 Controller
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
My right analog stick is broken. It sticks in one
hey chochie :-)
quick simple ansa to this....YOU DONT :-(
srry...
i have boxes of controllers with one analog stick broke (left or right) & even i dont fix them & i deal in controllers (i mod them)
Its a real big job to replace a analog stick when its damaged !
lots of de-soldering (to remove) (solder ****** working overtime)
& lots of re-soldering fitting the new (or used) one !
Trust me....ive tried ! I can do it...but its not worth the time it takes to repair !
srry maybe not the news you wanted to hear...but honesty the best policy !
take care :-)
Feb 11, 2010 | Microsoft Xbox 360 Controller
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
My analog stick is not working properly (PSP-2000)
I had the same problem, but with my PS2. try to get a replacement analog stick if you can do such a thing.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
My dualshock 2 controllers analog are very hard. how to fix it
Hi warren111,
When you say hard, did you mean the controllers analog stick is very "stiff" or loose to the point that you can't move the characters onscreen or the characters move involuntarily. If this is your case then you may have to try another PS2 dualshock 2 analog controller in your PS2, If the problem doesn't happen with another controller, then you may consider buying a new PS2 dualshock 2 analog controller since most likely the controller is already defective.
Also try other games, see if the problem only happens with a particular game. If it does then you will have to check the settings of the game, and see if you can adjust the settings of the buttons or analog stick.
If the problem you're having is more with the "comfort" of the controller you're using then you should consider looking at 3rd party controllers for the PS2. One company that makes them is Logitech, they have a line controllers that work for the PS2 there are other companies so check out gaming sites to get reviews on them. But I would suggest though that if you're shopping for a controller because of this reason, you should try to test the controller out in a game shop first. So that you can get a feel of it before buying. If you like the controller and you're comfortable with it then tha's the time you buy it.
Hope this helps!
Peace! :)
Oct 22, 2008 | Sony PS2 Dual Shock 2 Controller...
Psp
Your analog stick broke, it's constantly 'pulling' back and left, that's why that happens. You should let your analog stick replaced by somebody with PSP hardware experience.
Aug 22, 2008 | Sony PlayStation Portable (PSP) Console
Analog stick
then it is a internal fault is it under warranty if so id take it back and try your analog stick on the replacement one then your see if it your machine or the analog ?
Feb 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation 2 (PS2) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
