Question about Motorola Mobility RAZR V3
HANDSET LOST can you help me in finding it
    Scholar:
  • 151 Answers
Give your Fone id no to Motorola and block it. Then give complaint cop for it. And try to call ur fone from any other cell or fone....
Posted on Sep 23, 2007
  • 626 Answers
Check under the couch...
Posted on Sep 22, 2007
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
The second handset says "not registered" and won't work. I lost manual. How do I "register" it so the mainbase recognizes it, please? Thanks.
1. Place the unregistered handset on the charger.
2. Press and hold the FIND button for 4 seconds on the base.
3. Release the FIND button once the IN USE light starts to flash.
4. A confirmation tone will sound when registration is successful. Handset X is displayed where X denotes the number of handsets. The phone will then go back to idle.
just in case you need it:
User Manual Clarity D613C Combo Pack (D613 with D613HS)
Don't forget to rate if this was helpful :-)
Sep 22, 2010 | Clarity D613HS Phone
How to find a handset phone?
Just use the pager button on the base and listen for the ring on the phone. It will either beep or ring. If it is like mine you will have walked by it several times at least.
Mar 23, 2010 | Uniden TCX905 Cordless Expansion Handset
I have lost my lg kp500 mobile. Is it easy to trace it?
Short from calling your lost mobile number and physically listening for the ringing if nearby, sorry to say that it would say that it would be near impossible to trace it! The only option you have is to have your Mobile number disabled on that specific SIM card and report the specific EMEI for your handset as LOST so as to prevent the handset to be used on any Network thus rendering it useless ... and with a bit of luck, encourage the third party to return it!
Hope it helps and I am truly sorry that you lost your cell phone.
Jan 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
Gulliver (Hyundai CDMA mobile handset) handset code no.
try to reset it to factory default settings
Jun 24, 2009 | Cell Phones
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
Jun 20, 2008 | Uniden TRU8885 Cordless Phone
Onetel ot150 plus add handset
I don't have a second handset, but I'll quote from the instruction manual - Try this,
Regsiter up to 5 GAP cpmatible handsets to your OT150 base. New handsets must be fully charged.
You can use the same handset at home as well as the office by registering it to 2 bases.
1. At the base: press and hold "FIND HANDSET". You hear 2 beeps and the in use light flashes. Youa re now in registration mode.
2. At the handset: Press "OK". scroll down (with down arrow) to "REGISTRATION" and press "OK".
3. "REGISTER" is diplayed. Press "OK". Any free base numbers will flash. Enter the number of the base you want using the keypad.
4. Enter the PIN Number (default = 0000) and press "OK"
5. The handset searches for the base and when registration is complete goes into standby mode.
To test the handset is registered. Press "FIND HANDSET" on the base and the handset should begin to ring. Press "FIND HANDSET" again to stop the ringing.
As I say this is taken word for word (with a few spelling mistakes no doubt) from the instructions. I Hope that it solves your problem.
If you still have problems or you don't have the PIN number, the helpline number is 0845 226 7794, or e-mail help@telephoneproducts.co.uk
Mar 09, 2008 | Cable_and_wireless CWD4901 Cordless...
Motorola Mobility RAZR V3 Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
