Question about Penn Gt Series Levelwind Reels 330GTi
My Penn 114H cant't tighten drag,only to 12 lbs ,when I tighten the I can pull the line at 12 lbs
  • 234 Answers
Http://www.pennreels.com/
Call customer service.
Your drag is either worn or it is assembled improperly.
When I need parts or service, I call penn directly. They are the best reels out there as far as I'm concerned. And most of them are made in USA and backed by Penn.
It is the only reel that I care to fish with
Posted on Apr 21, 2009
Head tourqe specs for 403 olds and bolt tightening
Fig. : Cylinder head torque sequence, 260, 307, 350 403 Oldsmobile built engines
On the V8, tighten the bolts, in the sequence illustrated, to 100 ft. lbs. When all bolts have been tightened to this figure, begin the tightening sequence again, and torque all bolts to 130 ft. lbs.
On V6's, tighten all head bolts in sequence to the following torques:
* All except bolts 5, 6, 11, 12, 13 and 14 - 100 ft. lbs.(19-135.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 41 ft. lbs. (19-55.5 Nm)
* All bolts except 5, 6, 11, 12, 13, and 14 - 142 ft. lbs. (19-192.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 59 ft. lbs. (19-80 Nm)
Hope this help (remember comment and rated this).
Mar 29, 2010 | 1984 Oldsmobile Cutlass
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
I have a Penn 650 SS spinning reel Ihave loss the drag I have tighten it as hard as I can and it still has no drag
If the knob is not stripped, replace the drag washers under the drag knob.
Replace key #'s 6 and 56T with 3x 6-155 carbon drag washers, available here: http://www.mikesreelrepair.com/product_info.php?products_id=7806
this will bring your drag back to better than new condition!
Here's a schematic: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4123
Best of luck!
Mike
Nov 12, 2009 | Penn Gt Series Levelwind Reels 330GTi
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Mike
Sep 26, 2009 | Penn Gt Levelwind Series Reels
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Need 1990 nissan sentra torque settings and valve clearence
heinrichkemp: The engine in your car is a GA16i
I venture you are asking about the head bolts when you refer to torque settings. The head bolts used on this motor are torque to yield (streach bolts) If you are reusing them, you need to check them to insure they are not stretched beyond limits.
The way you measure the bolt is with a micrometer.
Measuring close to the end where the bolt starts to thread in, about 10-12 threads up, take a reading. Now, go to the other end of the bolt where the threads end and measure about 10 threads in.
There should not be more than a .009 inch difference (.228mm). If there is, discard the bold and get a new one.
You must use a sequence to tighten the bolts, below is the sequence.
11
13 9 3 1 6 8
14 7 5 2 4 10
12 15
torque 11,12,13,14 & 15 to 8.3 Nm (6.1 ft lbs)
Torque the main head bolts by the numbered sequence to
29Nm (22 ft lbs) first pull
64Nm (47 ft lbs) second pull
Loosten all the bolts completely
Tighten the to 29Nm (22 ft lbs) first pull
Tighten bolt # 1 clockwise 85 degrees
Tighten bolts #2- 10 65 degrees
Nissan noted that if you do not have a torque angel meter, you can use a regular torque wrench and torque all the bolts to 69Nm (51 ft lbs)
The valves on this engine have hydraulic lifters, consequently require no adjustment.
Apr 11, 2009 | 1990 Nissan Sentra
ur drag shud work if its tightened to the right or maybe its broke as u might of tightened it too tight before
Mar 20, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Penn Gt Series Levelwind Reels 330GTi Logo
605 people viewed this question
Top Penn Sport & Outdoor - Others Experts
Mike Marcotte
Mike Marcotte
raysaw
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
