Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Pixma MP210 Paper pulls to the right, tried more paper, less paper, different paper. Paper still pulls, jams and stops
  • 3 more comments
  • bafe Apr 21, 2009
    Thank you Richard, I shall try all your suggestions!
  • daytona22 Apr 23, 2009
    My printer pulls paper to the left, ive gried 1 sheet and 20 sheets. When (if) it prints, it sometimes drags 2 or 3 sheets, other times it trying to pull a sheet and it then gets stuck, another time it will pull thru a sheet without printing atall. Today I changed the paper setting to matte photo card cos it was doing all the above just to get 5 pages printed it took 20+ minutes as i had to keep re-printing/re-setting.
  • Anonymous May 10, 2009
    Mine pulls to the right too and I am about ready to throw it out the window! I have tried everything and it still pulls to the right, jams immediately and won't print.
  • amy_n_makayl May 14, 2009
    how do you clean the rollers????
  • Anonymous Mar 13, 2014
    Paper gets stuck on bottom of printer 2/3 of the tim. I have to pull out paper that is stuck, turn off then on, and try again. Most of the time it does the same thing again.
  • 385 Answers
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Posted on Apr 21, 2009
  • colleen garton Jul 05, 2013
    THANK YOU!! THis worked on my printer and saved me buying a new one, you rock!
2 Suggested Answers
APremkumar
  • 564 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printer pulls paper to the right...causes paper jam
possibly some paper is stuck in the printer. Can you manage to open the printer and check this out. If no paper at all then possibly carry it in for in-warranty service to the company outlet.
Jun 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have the same problem
You pulled out jammed paper from back? It might be some mecahnics slip or broke. Check paper feeder mechanics.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
The first page keeps jamming when I try to print
move the paper guides as close to the paper as possible. This should solve what seems to be a common problem with these printer see it all the time
cheers
Steve
complete inkjet solutions
Oct 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper completely jammed
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
1,108 people viewed this question
old marine
old marine
