Question about Dell A960 All-In-One InkJet Printer
Scanning it won' scan anymore it says to check power and to check port i did all it said still didn't fix the problem
    President:
  • Dell Master
  • 2,022 Answers
Change the usb cable and see. bye
Posted on Sep 22, 2007
My truck failed smog test because the check engine didn't turn in how do I fix it
If you are saying the check engine light is staying on, you need to have someone scan the computer for trouble codes, fix the problem, then clear the codes with the scanner. The light will go off then.
Most auto parts stores will scan for free in hopes of selling you some parts you may or may not need.
Jan 09, 2013 | Cars & Trucks
Konica minolta bizhub pro 920 won't scan to email
have you log in to the copier via page scope and properly set up the scan to email info required, such port, mail server, authenication procedures
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 28, 2012 | Konica Minolta Konica Bizhub Pro 920 Toner...
Obd2 port not recognising diagnostic tester
First I suggest to check fuses; keep in mind that the OBD-II port didn't work because the power wire in the connector corroded and didn't have a connection anymore. No power equals no OBD worked.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | Hummer H2 Cars & Trucks
I try scan my minivan but it won't read it
Check pin #16 of the diagnostic connector (powers scan tool) it should have 12 volts present, if not check you fuses.
Jul 19, 2012 | 1999 Chrysler Town & Country
I have a 2006 Dodge Caravan. The lights on the dash started flickering and the radio stoped working intermittantly. It won't start anymore and the power windows and locks don't work. We replaced...
did the battery check to be good? are the connections on the battery tight and clean? if so you may be getting a bad body control module , it controls power and ground to the systems you are having problems with.also check the ignition switch to see if you are getting power out of it to power the vehicle up.
Aug 08, 2011 | 2000 Dodge Caravan
Why does my laptop always ask me if i need to scan my hard drive to fix my problems? I'm afraid of scanning because it might delete or format the hard drive.
If your laptop has not been shut down properly then when you boot up it wants to scan fix problems caused by not shutting down properly or by power failure. It will not format your computer so you won't loose you data. You could lose a file that was opened or not saved when the computer was turned off. If you continually stop the scan and not let the computer fix these problems, it could stop your computer from working properly.
Apr 21, 2011 | Computers & Internet
I have the Lexmark X2670 and a couple days ago I scanned a document. Now I am not able to print anymore, I have items waiting to print when I check the printer, but the printer continues to print out...
Reset your printer by unplugging the power adapter from it(small black box behind the printer where the power cord is attached). Wait for at least 10 seconds before plugging the power adapter back in the printer.
Clear the print queue first before sending another print job. Follow the steps below:
Apr 07, 2011 | Lexmark X2670 All-In-One Printer
It does not scan anymore. How do I get the
Buying a new one is hardly problem solved for the benefit of anyone else with the same issue!
So you are throwing away a perfectly servicable printer because you couldn't find a solution by looking at the manufacturers web site?
Some people have more money than sense.
Jan 09, 2010 | HP PSC 1315 All-In-One InkJet Printer
Malibu 2004 radio unlock codes
The only way to unlock the radio is by using a scan tool. The scan tool sends the appropriate diagnostic message (relearn VIN) to reset the radio. Using a scan tool, select the radio VIN relearn procedure from the module replacement screen in Vehicle Control Systems......find some one with a Tech 2
Oct 30, 2008 | 2004 Chevrolet Cavalier
Dell A960 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
