Question about RCA HD52W58 52" TV
My 52'. the cable will not work. but the cable is good!
  • Anonymous May 24, 2009
    We have cable at our house. But, when we connect the cable to our tv nothing happens. It's just static. We had cable on this tv about 2 weeks ago. None of the other tv cables in our house work on our tv. What could the problem be?
  • Mike  Petrowsky
    Mike Petrowsky May 11, 2010
    Explain?
My cable channels dont work only 52 53 &54 series Lxi Tv
Try connection with a cable box that uses the audio/video output jacks and connect to a similar input on rear of set---you may have a bad tuner in the set and going via the AV jacks from a box to the set will bypass that.
Jun 10, 2012 | Televison & Video
RCA 52 HDTV Triple iamges in red, blue and green
I had the same problem with my RCA D52W23. I change out the convergence board and the 2nd fuse the one near the flyback. After getting TV back together picture was good except white backgrounds looked washed out with greenest at the edges. I called cable company and they came out fixed my cable line with was dropping and gave me a new HDTV box which was the newest one. That fixed my problems.
Apr 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cant get remote to video mode so i can watch dvds
you solve is easy and need check many options:
1.- read the manual step by step
2.- check your cable conexion, should be worked good
3.- retored the configution of fabric of the tv
4.- oh, don`t cross cable video with cable energy power or power supplies...
bye
Mar 07, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Do not remember code to unlock tv its a Mitsubishi WD-52327 52 is there a way to reset it
Thanks for visiting FixYa;
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
If that does not work unplug TV for 5 minutes, or you have bad buttons on your control panel. You can disconnect the board from the front of the TV. Take off speaker grills, remove cover(5-6 scews), unplug cable to control board. The TV will work with remote but not manually.
Good luck, Big Irish.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
I just picked up a 52' panasonic tv. when I turn
A lot depends on the quality of the cables you are using. If you are using the leads which came with your cable (scart leads) theyare not string enough you need to purchase gold platted leads in insulation...good manufacturers are belkin/ pure av. this goes for hdmi cables too. it is all well and good buying a good tv but you need the superior cables to use it
Aug 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
RCA HD52W58 52" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
