Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Riding moweer wont charge the battery when mower
Riding mower wont charge the battery when mower deck is engaged
  • Anonymous Mar 16, 2014
    What size battery do I need
    757 riding mower
  • 246 Answers
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
Why would a person need to jump start a battery on a john deere stx 38 to start it,if the battery is good ?
You have indicated a bad battery. There is enough charge in the battery to start and run buy not enough when you engage the blades. Check the battery by load testing it and checking with a multi-meter.
Jul 12, 2014 | Craftsman Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp 42" lawn tractor moweer deck hitting back wheel on right side when put all the way up. checked for broken parts but none found, help
The deck is either badly out of level or has been twisted by dragging on something. Most riders have rather thin metal used in the deck and it can be damaged much easier than one might think. Re-level the deck and use a small block as a gauge or eye reference point and you may find the deck is bent.
Jun 14, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower will not charge battery when blades are engaged.
safety switch wire maybe grounding out or insulation broken and touching body. how do u know they aren't charging. use a volt meter connected to the battery. crank engine, should be getting 13 volts plus on meter.
Jun 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tractor won't start. Battery fully charged but will not make a sound
kill switch is on? which would be the case when: mower perhaps engaged? or not sitting in seat? clutch not depressed fully?
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery will not charge
IS THE BATTERY GOOD,IF THE BATTERY IS BAD IT WONT CHARGE IT,IF ITS GOOD THERE SHOULD BE A 20 AMP FUSE FOR THE GHARGEING SYSTEM
Mar 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mower deck does not engage
Hello:
>>Check the Voltage from the Stator/Charging Coils.
>>A Bad Stator/Charging Coil will Cause the Problem you Described.
>>Thanks.
Respectfully
John
Apr 20, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
766 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
