Where is the computer on a 94 toyota truck (22re)
I am having a problem locating the computer on my 94 toyota truck
Most of the computers on Toyota trucks are located behind the passenger side kick panel under the dash
Posted on Apr 21, 2009
94 Toyota pickup 2.4 auto does it have a ground wire from distributor
Stephen, I believe there is just a 2 wire plug, no seperate ground wire. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
No start Due to Pickup Coil Failure Inside Distributor Toyota Camry Common...
How to Remove and Install Toyota 20R 22R 22RE Distributor
94 Toyota pickup 2 4 repair manual Google Search
Jun 21, 2016 | Toyota Cars & Trucks
94 Toyota pickup 22re High beams don't work but
sounds like your switch is bad . multifunction switches are cheap at a scrap yard
Sep 26, 2013 | Cars & Trucks
Is there a gasket in between the block and the heater pipe on a 94 22re? cuz i believe that is were my leak is coming from.
There is on o-ring or a copper washer....I have the same problem.
see this page for more information
http://www.yotatech.com/f116/22re-coolant-pipe-question-219737/
Nov 08, 2010 | 1994 Toyota Pickup
How to change a 94 toyota 22re valve cover gasket
In addition to the acorn nuts holding the cover down ... you'll need to remove any hoses, etc that prevent you from lifting the cover. You might as well do the PCV valve while you're there.
Aug 14, 2010 | 1994 Toyota Pickup
94 Toyota 22RE engine. Cold engine starts and
i would check the egr valve sounds like its sticking.
Jan 29, 2010 | 1994 Toyota Pickup
I have a 94 toyota 4runner that needs an engine. theres someone selling a 98 4runner engine, will it fit in my 94 toyota 4runner?
it depends, is it a 4cyl or 6cyl truck? If its a 4cyl, its a 22RE engine, any engine from 84 till I think 99 or 2000 will fit, the big thing is the wiring, if you just need the block and head, it should work. bolt everything else up and slap it in. should take about 4 or 5 hours depending on how much you know about engines. If its a 6cyl...your on your own.
Jun 20, 2009 | Toyota 4Runner Cars & Trucks
Where is the computer on a 94 toyota truck (22re)?
Right passenger kick panel. Below the glove box. It has three wiring connectors hooked in to it. I believe the connectors are yellow.
Apr 21, 2009 | 1994 Toyota Pickup
1994 toyota 22re 4x4 pickup fuel injector wiring diagram
the color of the plastic plug does not matter... You will have two injector plugs with white/red and yellow wires - those two go to cyl#'s 1 and 3.
the other two plugs will have white and blur wires.. those two plugs go to injectors # 2 and 4.
Oct 09, 2008 | 1994 Toyota Pickup
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
