Question about HP Pavilion dv4015CL PC Notebook
Computer ranbdomly shuts down
I have the HP Dv4015cl. Recently the computer has been shutting down for no apparent reason, usually if I am watching a video or playing music, but sometimes for no reaeson at all. I assumed it was a virus, so I attempted to reformat. Now the computer shuts down before it can finish installing xp back on my system. It seems to me that there is a problem with my RAM, but I wanted to see what you guys thought. Thanks in advance for any help you can offer.
  • phat_matt109 Apr 21, 2009
    Thanks for the response, the laptop actually belongs to a friend of mine, so i'll see if he's run a virus scan. Without the OS on the system, is it possible to run a virus scan? Sorry if this is a dumb question but my knowledge of these things is shaky at best, but still much better than my friends.
  • phat_matt109 Apr 22, 2009
    Wow, thank you for all of the great info. After my last reponse, but before your subsequent response i had my friend just put some books underneath the lap top in order to create better airflow, just to see if it would have any effect. The reformat went through successfully. I had my friend go to hp.com to make sure all of his drivers and BIOS are up to date. He now says the computer only crashes while running Media Player. Im still assuming that your correct and there is a problem with over-heating. Ill have him buy some compressed air and bring his laptop over so that we can complete the cleaning process. Thank you again for all of your great help and advice, i'll let you know how this ends up. Let's keep our fingers crossed!
  • HP Master
  • 5,660 Answers
Your last question was very observant. NO, without an O/S, there is nothing to make a anti-virus program run.
I suggest the problem in the beginning, was that the laptop was overheating. Once the processor becomes too hot, (Processors have a thermal limit), it turns off. (To be more precise, the BIOS program turns it off)
This is a Fail Safe feature built into all processors, (Along with the BIOS program) The processor is shut off to keep it from burning up.
Laptops have a poor cooling design to begin with. All of the hardware components, are crammed into one tiny box. Add to this, that typically there is just one small fan, to cool the components. (Some laptops do have more than one fan. These are usually high-end gamer laptops, and some 'barebones' units. Not your typical laptop)
Add to that, the Air Intake Duct is typically located on the bottom of a laptop, or on the side. (Most of the time it's on the bottom, with the Exhaust Duct on the side)
The Air Intake Duct narrows down to a Cooling Tube. Makes a funnel effect. (The Cooling Tube is connected to a Heatsink sitting on the processor, with the fan blowing air on the heatsink. Some Cooling Tubes extend beyond the processor, and help cool the Northbridge chipset)
Now add to this, that the Air Intake Duct is in an excellent (?) position to **** up foreign debris.
Dirt/Dust/Hair/Food Crumbs, you name it. Doesn't take long, for this foreign debris to build up on the inside of the Air Intake Duct, and also clog the Cooling Tube, Heatsink, and Fan blades.
Doesn't take much, and the cooling capacity of the cooling system, drops exponentially.
When you are using your laptop, the processor has millions of Electrons running through it. The processes the processor computes, makes the processor heat up. The more intense a program is, the harder the processor has to work. More heat is developed. The cooling system must keep up with this, or the processor reaches it's thermal limit, and turns off.
Now you have attempted to reformat the laptop with either a Restoration Disk, or a Full Installation disk. This is an intense program for a computer, (Laptop or Desktop), and the processor is operating at 100 percent. Once the thermal limit has been reached, the processor turns off, and you have a blank harddrive with No Operating System.
So what is the solution?
I suggest trying to clean the Air Intake Duct out first.
AC Adapter (Charger) removed from the laptop. Battery removed. Buy a can of compressed air for computers. Break the plastic lock tab, off of the top of the can of air. Insert the plastic 'straw' into the nozzle. Work on a table. Have your friend hold the laptop up on it's side. If the Air Intake Duct is on the bottom of the laptop, preferably have the Air Intake Duct down towards the table.
To explain further. Looking at the bottom of the laptop, bottom facing you, laptop up on it's side. Air Intake Duct is close to the table.
Start by spraying air, about one finger length away from the Air Intake Duct grille. Start at one side, and come across. When you start, depress the trigger in all the way, let go when you reach the other side. It's just like you're spray painting. (Properly!)
Now drop down a row, and go across again. How far down to drop to make that second row? Use your judgment. You will be able to judge how wide a fan spray the air makes. You may see dust blow off, and can judge it by this.
Keep going down in rows until you are at the bottom of the grille.
Now come back up to the top where you started. This time, bring the straw right up against the grille.
BUT, this time you are going to use Short Bursts of air.
Squeeze the trigger in all the way, but let go quickly. Angle the straw, at a slight angle towards the bottom. You are trying to blow air in, and still have a path for the foreign debris to come out. Go across, the drop down a row, as you did before. Go all the way down the grille, until you are at the bottom.
You are using Short Bursts now, because the straw is close to the grille, and a lot of air pressure is being 'pin pointed' in a small area. The high pressure of air, is going straight through that Cooling Tube, and will spin that fan. You don't want to spin the fan too much faster than it was designed for, or you could cause premature failure of the fan's bearings. (The fan will quit spinning way before it's time. Before the 'Life Cycle' of the fan)
Using the can of air, the directions will state to not tilt the can, or shake it. When doing a good job, it is inevitable that you will tilt the can. You will see, what looks to be like moisture, coming out. It's the propellant in the can, that pushes the air out. Try not tilting the can. Bend the straw a little, with a finger from your other hand.
Also after using the can of air for a while, it will seem as though the air pressure is dropping. Slowing down. It is. The air is coming out of the can so fast, that it's freezing moisture in the outside air. (Also the propellant is usually propane gas, and this cause that effect too) You will see that frost is developing on the top side of the can. Just set the can down, and allow it to warm back up for a few minutes (10?) then you can use it again.
DO NOT spray the Exhaust Duct out!
I invite you to now, bring the laptop back to it's normal position, but prop one edge up on a book. Give any moisture that may have built up inside, a chance to dry out. (10-15 minutes)
Then when you are satisfied the laptop has dried out, plug the battery back in FIRST, then the AC adapter (Charger)
Press the Power On button, and see if the laptop comes on. Not boot up to Windows, just see if it comes up to a screen where you see -> F10 = Based Setup <- message in the lower left corner.
Press the F10 key.
You will now be in BIOS Setup, and see the main menu. Use the Down Arrow key, and 'highlight'
-> Advanced BIOS Settings <-
(It may state Advanced Settings, or Advanced Options, or Advanced Menu)
In the Advanced Menu click on -> Boot Options <-
You will see different devices listed in an order. These are devices in the computer, that it uses to boot up from. BIOS will go down through this order, starting at the top device listed. You want CDROM listed first. You are making CDROM as the first boot device.
(No, it doesn't matter if you have a CD drive, or a DVD drive. You are making whatever optical drive you have, as the first boot device)
To change the Boot Order, look down at the bottom of the screen. You will see a Navigation Guide.
It won't state navaigation guide.
It will state -> Change Value, and either have +/- listed, or Page Up/Page Down, listed.
The + key is along with your -> = <- key. The -> - <- key is with the Underscore key. ( _ )
Use the Up or Down Arrow key, and highlight -> CDROM.
Use whatever Change Value key's it shows. I suggest trying the Minus key first. ( - )
(If this is the key they list)
There is a variation. Sometimes,, you have to highlight the first boot device listed, and use the Change Value key, to move it down the list. Keep experimenting, until CDROM comes to the top of the list.
Once you have CDROM at the top of the list, it will be the first boot device.
Press the F10 key.
Now press the y key. (Y is for Yes. Yes you want to Save Changes)
Now press the Enter key.
Try to get that Windows XP installation disk in your optical drive, as quicly as possible. (CD or DVD drive)
Your computer will be booting up from the WinXP disk.
Should you miss this window of opportunity, DON'T sweat it!
Get the XP disk in there.
Now press the CTRL , ALT, and Delete keys, AT THE SAME TIME.
Your laptop will restart, and boot from the XP disk.
This is the Maintenance and Service Guide for the HP Pavilion dv4015cl laptop. From HP.com/Support.
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
You just copy and paste the link above to your address bar, then press the Enter key.
Give it time to download. It may take as many as 20 seconds until you see the first page. Until then, it will seem like nothing is happening at all. After you see the first page, I suggest you wait until the download has finished, before looking through it. (This states its a Service Guide, but it's really a Service MANUAL)
If the above link doesn't work for you, then go here,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=459480&lang=en&
Click on -> HP Pavilion dv4000 Notebook PC and Comapq Presario V4000 Notebook PC-
Maintenance and Service Guide<- , in blue. (Size 3.3MB)
Posted on Apr 21, 2009
    Sergeant:
    Champion:
  • 259 Answers
Rather than re-installing windows have you tried running a virus checker ?? as for the ram i wouldn't think so not if it shuts down for no apparent reason as a point of interest from what i have found that reinstalling windows won't get rid of a virus hope this helps regards Jim
Shuts down
This is a typical symptom of a failing power supply. Replace your power supply and see if the problem still persists.
Please notify me should you need any further assistance.
Best wishes,
Graemevm
Jan 06, 2012 | Intel DP55KG Motherboard
My hp 1630n keeps shutting down for no apparent reason. sometimes it goes all day then shuts down, sometimes for 10 mins. it isnt running hot either. replaced power supply with one that is 400w and it...
This might be an indication that a hardware is failing. go to BIOS and leave it turned on, see if it will still shut down randomly. If it does, then it is definitely a hardware problem. If it still under warranty, call HP for support. You can also visit HP Support Website for more info.
If it is hardware problem, try isolating it by re-seating the parts which has an integrated chip like RAM, VIDEO CARD and CPU. If you have two sticks of RAM, try each one without the other and see which one is failing. You can also switch to the integrated video if you have one to test the graphics card. Make sure you have the proper knowledge on how to handle these parts as this might cause damage on the computer and electric shock.
Mar 23, 2011 | HP Pavilion a1630n PC Desktop
I have a hp pavilion ze5170 laptop and it is shutting itself off for no apparent reason. anyone know what could be causing this? it doesnt appear to be software related. its not crashing just turning off.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion ze5170 Notebook
Boots up fine runs for awhile then shuts down for no apparant reason.
Most times if computer runs and then shuts down it is mother board over heating. It shuts down to prevent damage. Try to clean you mother board fan and also make sure no dust in the exhaust part on the bottom of the computer. You can clean it with air can for computers just make sure you hold it upright because if it is sideways or upside down it will put out freezing air and it can damage you computer. Hope this helps.
Jan 13, 2010 | HP Pavilion ze5270 PC Notebook
Unit keeps shutting down Lenovo 7757 Laptop.
Could be related to a heat issue if it just powers off for no apparent reason.
Try cleaning your fans our with some canned compressed air available at your local retailers such as Walmart, Fred Meyers, or Walgreen's.
However, if Windows displays that it is going to shut down due to low battery, you may try gauging if your battery life has significantly decreased. Less than 60 minutes is usually a good sign to replace the battery.
If Windows is just shutting down without any messages you can attempt to clean any malware off your computer by using Malware Bytes from www.malwarebytes.com. Also looking using Microsoft Security Essentials as a normal virus scanner (free).
Nov 26, 2009 | Computers & Internet
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
My HP DV1000 keeps shutting down whenever I watch videos or do anything on my computer which is more than the basics of surfing the net. When it shuts down, the computer is hot so I attempted to remedy the...
hi this all hp is getting same problem
i have solve many, but u need to open up ur notebook and have to do all cleaning ,u can open ur notebok,
or else do onething, uses vaccum cleaning ,see behind ur laptop a fan site **** all dust through vaccum cleaner, it will clean and problen shouild be solve or else u have to open whole notebook
thanks a lot
Aug 16, 2009 | HP Pavilion dv1000 Notebook
When is the Hipro HP-A2007AE power supply cooling fan to be on?
The fan should run constantly. It needs to be replaced. Otherwise the power supply will shut down when it gets hot. It can usually be replaced, but if the supply is cheap, just go out and get a new one.
Mar 17, 2009 | Computers & Internet
Computer shuts down
most pcs will shut down to protect themselves in some way. need a bit more info, age, make etc
Jan 11, 2009 | Computers & Internet
Computer shutting down randomly in the middle of everything...even offline games
This can be the result of a virus infection or an infection of other malicious software such as spyware.
Run a thorough system scan.
If this doesn;t help, tell me and we'll go to the next thing to check/do for this kind of problem.
Greetings,
DarkNeogen
Jan 25, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion dv4015CL PC Notebook Logo
188 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
