Question about Rosewill R900J 19" Flat Panel LCD Monitor
When i try to turn on the monitor there is no power or stanby light to indicate that the monitor is on, and I check the power point where i plug the monitor that it is ok,so can you please help me to fix this problem
    Problem Solver:
  • 17 Answers
FIRST OF ALL TELL ME WHAT KIND OF TV IT IS
Posted on Apr 21, 2009
The stanby light goes on and returns
Hello
If the power indicator is blinking on the front of the VIERA, turn off the TV and unplug all HDMI cables that are connected to the TV. Then unplug the power cable from the current power source. Try a different electrical outlet. Remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
Apr 23, 2011 | Samsung WS32Z308P 32" TV
The cpu is running,the motherboard is with green light inside,but the monitor blanck
what king of monitor you have., crt or LCD, does the monitor led indicator has a green light, is there any beep when starting the cpu? how many beeps you have heard when the cpu was starting?.
if there is no led indicator light in you monitor the posibilities of that is the monitor was the problem.
solution: try to check your plug in monitor if it is properly inserted in the power plug or in the vga plug correctly.
if when you power the cpu and your monitor led indicator, turn green and back in the standby mode. listen to the beep sound of cpu if theres any.
solution: try eject the mem card. in the slot and clean the contact with the eraser. and put it back into the slot again after you clean it.
Mar 28, 2011 | Computers & Internet
The monitor will not come on when i turn it on
1. - Check for power at the socket. (plug in something else)
2. - Check for power at the power cable. (plug the cable into something else you know works)
3. - Plug into monitor, and see if ANYTHING lights up when the power switch is turned ON.
4. - If you get some indication of power, try a new cable to the PC, or plug into different PC. That will localize if it's the monitor, the cable, or the PC.
May 28, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
May lcd monitor dell not power
If there is no power or "Led" indicator on the power button, try plugging the power cable to a different power point. If still won't turn-on, try changing the power cable. If still no power. It only means the LCD is already deffective.
Hope this helps.
Mar 28, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Samsung tv monitor 940mw
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 18, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Lg 19
Is it over heating? Is your computer set to let the monitor go into standby after a certain amount of inactivity? Check any and all power settings. Next time it happens, have a feel to check and make sure it isn't over heating...
Dec 18, 2007 | LG L1920P 19" LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
44 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
