Question about i-mate PDA2k Pocket PC
Cannot install application on my pda2k
I just purchased this new pda2k but cannot install any application the error message comes out always not a valid pocket pc application
    Problem Solver:
  • 17 Answers
You need to check whether it's an .exe file or a .cab file. If it's a .exe you need to first install it on your pc nad then via activesync install it on your PDA2K. If its a .cab file you should be able to install it directly on th PDA2K. ps If you try to run the .cab file on your PC it will say its not a valid apllication with the corresponding windows error code.
Posted on Sep 24, 2007
SOURCE:
My Phone is working properly but in the recent past i have changed the default security code of my phone and have forgotten the new password set. I would like my phone to be restore factory settings but...
You can try by using the master security code .This code can be got from the following link by providing the imei no.If the master security code does not work.There is a option reset security password only by using the flash utilities for this contact service centre
Jun 15, 2010 | Nokia 6270 Cellular Phone
Tip
ITunes Error 13010 - How to correct this error in iTunes
As with any application in any operating system in this high tech computer industry today, there is always going to an error of some kind. How that error can be eliminated, is always the principal concern of any computer user of a Mac or PC.
One of the errors I would like to provide a tip for you, on how to resolve, is the "Error 13010" error message, which affects users of iTunes in Mac OS X.
The Error 13010 alert, will usually appear when a user is unable to launch and open iTunes. More often than not, however, the fix for this error is a relatively easy one.
Here are steps for you can implement to eliminate this error:
For Mac OS X
• Make sure iTunes application is closed.
• Click anywhere on the blank space of your desktop and Finder will appear near the Apple menu icon located in the upper left corner of your screen.
• From the Finder menu click on Go> then select Go to Folder
• You will need to type /Users/td7/Music/iTunes in the open dialog
box:
• This will take you directly to your iTunes folder.
• Within iTunes folder, locate and remove to the Trash,
the iTunes Library Genius.itdb. file
Once you have removed this file, close the Finder window and relaunch
iTunes.
Launching iTunes will restore a new iTunes Library Genius.itdb file
and as a result, no longer see the Error 13010 alert message.
In the event that this procedure does not allow you to launch iTunes normally, you should remove iTunes and re-install the application.
But don't worry though, you will not lose your iTunes Library, as that remains untouched in the Music folder.
You are simply going into your Applications folder and removing iTunes application and then reinstalling it.
Here is the link for downloading and re-installing iTunes, as needed:
Download iTunes '09 for Mac
So now you have at least one workaround, from a number of iTunes errors, should it manifest, which you can use to resume normal functionality of your iTunes application.
I will be providing more tips in future articles covering workarounds like this, for the various error codes which can affect the functionality of either the Mac OS X platform or any applications installed within its volume.
As always, I hope this information proves beneficial to you in some way, if not now, in the future, should such an error like this adversely affects your iTunes application.
Thanks for reviewing this Mac OS X Fixya Tip.
Regards,
-Mactechtrainer
on Apr 09, 2010 | Apple iTunes
PDA2k Pocket PC: how do i install antivirous in my imate pda2k?...
download this file.copy to your device and run!
http://bit.ly/aVZeLE
May 06, 2010 | i-mate PDA2k Pocket PC
How to install sotwares in i- mate pda2k pocket pc.
To install softwares you need a computer installed with microsoft active sync 4.0 and above.This enebles your phone to communicate with the p.c.
Then, i believe you posses or may need to purchase pocket pc softwares that are compatible with windows,and these range from games to even GPS software all for your PDA.These softwares are available online.
Nov 02, 2009 | i-mate PDA2k Pocket PC
Cant save the theme that i download for my nokia e61 it always says certificate error
If you try to install a theme and see the above error message "Certificate Error. Contact the application supplier" You are trying to install an application that is not Symbian signed
The solution is easy. Simply switch the setting in the Application Manager from "Signed only" to accept all - "Software Installation: All"
You can find the App. Manager Here:
Menu > tools > application manager > options > settings > ......
If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 02, 2009 | Nokia E61i Cellular Phone
3 software packages won't install or run.
TRY,, DRIVER MAX free program i always had problems with driver detevtive
May 22, 2009 | HP Pavilion m7480n (882780389410) PC...
I have an i-mate PDA2k Pocket pc. all applications(everything including mediaplayer, word) are missing from my 'programs'menu. I am not sure whether they have been deleted...
Have you used your 'file browser' (if you hit start this should be one of the options) to see if the applications are in fact still on the phone?
Apr 11, 2009 | i-mate PDA2k Pocket PC
EA Sports Tiger Woods PGA Tour 08 Game won't run on PC
http://www.fix-all-dll-errors.com/d3dx9_32.dll/
You can get it from the above link.
Once you go to the above link click "Fix dll errors now" button and it will fix the problem.
Dec 28, 2008 | EA Sports Tiger Woods PGA Tour 07 for...
Vison Monitor ( device installer error)
First you need to uninstall the driver for your old monitor. Then install the driver for the new monitor. With both drivers installed your computer is confused and shows the conflict as an error message. Hope this helps.
Dec 23, 2008 | Computers & Internet
Skype calling software
I just fixed this problem on mine.
You need to upgrade your Active sync on the computer, then download the setup file for Skype 2.2 for mobiles, then run it on the PC when Active sync is active.
Follow the installation and it'll install it to your PDA2K. You'll have to delete the old one though - and it won't work via a USB internet connection - only WIFI or GSM.
Now to find out why my wifi won't work.
May 15, 2008 | i-mate PDA2k Pocket PC
i-mate PDA2k Pocket PC Logo
285 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
