2004 Ford Focus Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a transmission for a 2002 ford focus fit a 2004 ford focus(both are sedans)?
Does atransmission for a 2002 ford focus fit a 2004 ford focus zts?
  • gerry bissi May 11, 2010
    it should fit
  • Anonymous Mar 14, 2014
    Is there a typical problem when I get a code p0411 on my 04 2.3 l focus?
Jefferson Sotto
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Apr 23, 2015
Jefferson Sotto
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
17992
Points
85
Yes they do both sedans just different years but from 2000 to 2004 are the same just like 2005 to 2007 ford focus..
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Jul 22, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
0
Helped
34481
Points
149
If the engines are the same they will fit, the splitport and the zetec use different trans.
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Apr 22, 2009
Anonymous
Expert
Level 2:
Answers
126
Questions
0
Helped
50510
Points
406
If the numbers on the bottom of pan match .
Will a shift cable in a 2002 ford focus work in any 2002 ford focus like a ford focus zts sedan?
if they are both 5 speed boxes then it should be the same and will work
Is there a difference in shift cables in a 2002 ford focus' s?
They will be the same part number so it should wirk
2003 ford focus ZTS sedan - engine light is on. enough oil, has coolant
check the engine breather pipes under the manifold at the front of the engine ,could be these pipes are perished causing your problem
2004 Ford Focus ZTS with DTC P2004.
my 04 zts was throwing the same code. I got under the car and found a vacume hose that was off of an actuator thing ,put it back on and hasn't thrown code since
1helpful
A rattleing noise when hitting small bumps?
have you checked the sway bar end link bushings?
How to replace a starter on a 2004 ford focus zts 2.3l engine
same way u take it out put it in all else fails read instructions
2answers
How do you replace the tail light in a 2003 Ford Focus ZTS sedan? not a hatchback
Open up hatch , reach in and pull back liner, Remove nuts to release light lens. then push, turn and pull out bulb socket and same for bulb.
1helpful
2answers
Automatic Transmission is not working in any of the gears.
sounds like your torque converter went bad.
start with check transmision fluid level.
1helpful
3answers
Engine?
not sure what the sound was, but if there's a blown head gasket, the water that gets in a cylinder won't compress and it won't turn over very well and sometimes not at all. that may be what they mean by "holding compression".
check for water in the oil...it'll foam up on the dipstick,
Get a second opinion from a reputable shop other than Ford.... If it's a head gasket, it's much cheaper than an engine swap, if that's what you're thinking...
1helpful
Rear brakes
bskelly;
try this link: http://auto.howstuffworks.com
You can do a search "replace brake pads"
This is a fantastic web page to have in the "favorites" of your browser.
Hope this helps. good luck Loringh PS please give me a rating Thks
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
