Question about HP Pavilion dv4000 Notebook
Speakers stopped working, quick touch button stays red.
Was working great, then it happened. The speakers won't work. The quick touch button (next to vol. control) is now always red, but it works with the head phones pluged in. Anyone have an Idea?
Thank Dave
  • 385 Answers
1, type DXDIAG in the run box, do the tests, see what the results are. should tel you the problem.
2, go to control panel, sound, check your settings are correct, there are 2 settings, speakers and
headphones, check they are correctly set.
3, Update the driver,
contol panel, system, device manager, sounds,video & game controllers, click this, tab under it appears, double click this tab, driver dialog box appears for you, driver tab, roll back, or update the driver, let it roll automatically, it will search the internet for it.
Should be good
Regards
Richard.
Posted on Apr 21, 2009
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
Bose Cinemate remote stopped working
Ive had the same problem, basically happens anytime we lose power or if it gets unplugged. Great speakers, poor design. Im not having any luck this time. Gonna try leaving it unplugged longer, like days this time. The remote feels like the problem, any button just causes the TV/VCR/AUX/ect row to blink, can't program it or anything. Seems like this is a common problem
Mar 16, 2012 | Bose Cinemate Digital Home Theater System...
I have no sound from one channel. I have swapped speaker leads (sound just swops with the speaker). I have taken lead out of CD player and touched ends of leads for "earth hum". Only get hum on...
If the sound stays with the speaker, then the problem is with the speaker not the receiver (unless I misunderstand). You state that changing the speakers that the sound stays with the speaker. This means that both channels are producing sound, it is the speaker which is defective. You can verify this by using a 9V battery. Quickly touch the leads from the speakers to the battery. You should hear a pop or click. If the speaker is defecive, you won't hear anything.
Let us know what happens.
Dan
May 08, 2011 | NAD C350 2-Channel Amplifier
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
The internal speakers on my ipod touch don't work
As far as I know, the sound quality coming out of the ipod is not so great to begin with. I have an iPod touch, and the speaker I have right now was only $12.59 and the sound quality is great. plus I have my headphones from UxSight. They are amazing. Here is the link: iPod speakers
Sep 30, 2009 | Apple iPod touch
Won't stay on, turns off by itself
With a 1.5 Volt Dry Cell (AA Size), connect two pices of wire with the Cell. Momentarily touch the wires with speaker several times. It should produce click sound when wires are touched. If not then speakers are defective and need repair. Do not touch the wires for more than a second, touching the wires for a long time may damage the speakers.
Jul 06, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Kenwood dnx7100 in protect mode
Your receiver is detecting a problem in the speaker wiring and is going into protection mode. If the receiver shuts off due to volume level, this can be caused by a poor connection, damaged speaker, insufficient gauge wire, or connecting multiple speakers to one speaker output. The connections at the receiver and speaker should be clean with the ends of the wire twisted tightly, preventing any strands from missing the terminal. Connecting two sets of wires together to add distance should be done with terminals and insulated to prevent the wires from touching each other. If using thin wire, replace completely with heavier gauge wire; do not add to the existing length. Be careful not to push the speaker wires in too far, this will cause the speaker terminals to grip the insulation and not the conductor. The speakers being used must have an impedance within the range listed next to the receiver’s speaker outputs, normally between 6? - 16?. The impedance of your speaker should be listed behind the speaker itself.
If problems continue, disconnect the speaker wires from behind the receiver and power the receiver on. The receiver will shut off quickly if there is an internal short and would need to be serviced if this happens. If it stays on, try connecting the speakers one at a time. Replace any speaker that causes the receiver to shut off.
Thanks.
Jun 24, 2009 | Kenwood DNX7100 Car Video Player
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
HP Pavilion dv4000 Notebook Logo
186 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
