Question about Kodak ESP 5 Printer
Hello. I took the back off my Kodak esp5 to clear pieces of paper that jammed. Now I don't see a way to replace the back.
  • 295 Answers
Go to www.kodak.com/go/manuals and download the manual. it will guide you on how to solve the issue. anyways the bottom side of the door needs to get in first and the you need to push it from up and you are ready to go.you will hear a click sound.
Posted on Sep 21, 2009
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
Printer paper is jammed. Is there a release?
is there a... what? you didnt provide additional information, and you left the question unfinished. is there a way to remove the paper? is there a solution? yes. the paper can be removed. but i dont have enough information.
Product summary The good: Improved photo quality over previous model; attractive design; large 3-inch LCD screen; easy-to-use Home Center software.
The bad: Poor quality build with several mechanical errors; average print speed; graphics quality still lacks definition.
The bottom line: The Kodak ESP5 is an attractive full color all-in-one printer, scanner, and copier, and casual photo enthusiasts will be happy with the watered-down editing software, but hard-core users should look elsewhere for a multifunction printer. The ESP5 is too expensive and suffers from too many mechanical deficiencies for us to give it our CNET stamp of approval.
you will continue to have these paper jams.
Jun 04, 2010 | Kodak ESP 5 Printer
How to fix paper jam in kokdak esp5 printer
www.kodak.com/go/itg
Select all-in-one printer
Select paper jam and follow the steps
Jan 15, 2010 | Kodak ESP 5 Printer
I have a ESP5 printer. There is an error message that says I have a paper jam, but I cannot find any paper.
A Piece of Paper may be in there. Find out it by replacing Catridge. Off the printer switch, See inside, out the paper from tray. Then keep it one by one.On Printer
Dec 10, 2009 | Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
Kodak ESP5 Printer - actual paper jam
you can pull it out from front and if you don't want pul it out from front just open up the cover of roller then take off the paper.
you are done
Good luck
Feb 09, 2009 | Office Equipment & Supplies
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Kodak ESP 5 Printer Logo
244 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
