Question about ASUS (M2NGREEN) Motherboard
Only one drive showing out of two
M2N68-LA duel harddrives only one working after pc crash had to reinstall new vista not the hp one as it wouldnt load computer only reading one drive now i changed the leads round and there working fine so problems not there vista telling me all hardware is working any ideas
  • karmaxxxx Apr 21, 2009
    thanxs @ dickcanfixit hope this post helps anybody with a hp pavillion computer with duel barracudda drives after a firmware update from hp to stop the barracuda drives hanging models (st3500620as) machine crashed killing even the recovery options hp installed on the bios or even microsoft recovery options failed to initialise had to do a clean install wiping out both drives using webroot disc erase load vista back in to machine at first machine was reading disc as a 32bit not 64 bit so had to erase everything again and start over which was strange to say the least as i only have a 64bit disc came backup as 64bit but only one harddrive showing machine saw disc array but would let me use it was hidden i sorted this by right clicking computer then clicking manage then clicking disc management clicked on the effected disc renamed then formatted the disc and hey presto alls back up and running hps stance hmm ive asked them for the discs to restore original factory setting as it was not any fault of mine only theres as of substandard eqiupment they used awaiting response there customer care team didnt really have a clue or didnt read my email properly will advise if hp respond in kind thanks for all your help karmaxxxx
  • Dick
    Dick May 11, 2010
    If you truly have "duel" hard drives, one has killed the other. It must have been a duel to the death. Better hope your remaining drive is not injured too badly.
    If you mean you're running two hard drives (dual) then make sure one drive is set to master and the other to slave if you have them on the same cable. If they are on different cables you need to make sure one device on each cable is master and the other device on the same cable is slave. Does the BIOS recognize both drives? If not, one drive is probably damaged beyond repair. It may be possible to recover the data from it but it won't be cheap.
    Sergeant:
  • 210 Answers
Hi the cable ribbon is color coded. the blue should be connected to motherboard and the gray is a slave and the black is master. Check if you have this connected properly. If you got a Cable ribbon not color coded. The cable ribbon from motherboard connector about a 12 inches long from middle slave connector and 6 inches to the master connector. If this is not connected properly and HDD is not assign slave and master most likely the OS can not detect the HDD. The other way to check is to access your bios setup if the slave and master HDD is detect. Your PC have a capability of plug and play if you connect the hardware right and load the driver. Hope this info will help you to solve the problem.
HH
Posted on Sep 05, 2009
M2N68-LA (NARRA3-GL8E) Motherboard Manual - ASUS Owners User Manual
There has been a lot of confusion going on around the net. However I find the driver which should work just fine with your model. However the driver is from HP/COMPAQ and the model is M2N68-LA (Ivy8)
You can download the drivers from this link
Documentations will be available here
If you have doubts let me know.
Nov 04, 2011 | ASUS M2N68-AM SE2 Motherboard
I bought this HP Pavilion a1610n and it had a dead 250 gig sata harddrive(western digital).I installed a new 250 gig harddrive western digital sata drive in this computer(motherboard is a A7VBX-LA)I cannot...
Here are the original drivers for Xp on top and Vista on bottom not sure which you have or need.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
Sep 14, 2011 | HP Pavilion a1610n PC Desktop
The hard drive crashed will not start
If the hard drive have crashed meaning that the hard drive itself is damaged, then your solution is to replace a new harddrive. If you do have a recovery disc already made, or one is provided then you will have to use that disc once the hard drive is replaced with the new one, and follow the procedure to reinstalled the operating system. If the original hard drive had crash and does no work anymore (where the bios/computer cannot detect it) and you have important data that you would like to retrive, there are places such as office depot, bestbuy, where they can help you send it to a recovery file center to recover files from your damaged hard drive. Do not attemp to fix or open a damaged harddrive, you can forever damage the files on the cyclinder disc. 2) Now if your harddrive crash in term as windows just crashing and you cannot get into your operating system and the bios is still able to detect the hard drive, and it's giving you a error message, then you will only need to reinstall, or do a windows recovery through your recovery disc, If you do not have a recovery or made the disc, then you will need to buy a new operating system software. If you computer does not start meaning no display on the screen at all, then please replay back. That is a different story.
Feb 06, 2011 | Acer Aspire 7720-6569 Notebook
The previous hard driver was bad. I replaced it with a new hard drive. I used the Toshiba default factory setting to reinstall the softeware and now my laptop will not boot up.
Toshiba default factory setting can only restor your software if you have backup copy on New Harddrive.
As your old Harddrive crashed, you have to reinstall Operating system and requie software on new Harddrive.
Mar 09, 2010 | Toshiba Satellite P205D-S7454 Notebook
Hard drive is very hot and sounds stranges
Hard drives typically run pretty hot and have a cooling fan to make sure they don't overheat. The fan vent are easily clogged with dust that can build up to make the fan almost useless. Power off the computer and let it sit idle for about an hour and unplug power cord then open the case. Carefully brush away dust that has accumulated inside the case, making sure to clear the vents around the harddrive and the power supply. If the harddrive continues to make strange noises, I would strongly recommend making a full backup and get a new harddrive ready. When it comes to harddrive crashes it's not 'if' but 'when'. It will eventually crash, and true to 'Murphys' Law' it will crash when you most need it.
Jan 19, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Blue screen compaq presario vista
yes look first try to reinstall the operating system if the problem is still your harddrive must be crashed
Oct 24, 2009 | Compaq Presario C700T Notebook
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
Mar 14, 2009 | ASUS Computers & Internet
Won't boot up
Buy a new harddrive and install a new OS on it
make sure your old harddrive is disconnected
after the new hard drive is working properly then reconnect your old harddrive and
u will have all your files back unless the old hard drives crashed completely
Oct 18, 2008 | Gateway GT4022 PC Desktop
ASUS (M2NGREEN) Motherboard Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
