Question about Dynex 32 in. LCD Flat-Panel HDTV
Half of screen is yellow
Brand new 32" Dynex LCD TV (2 months old). Half of screen has distinct yellow hue the color on the other half is fine. I checked all cables to no avail.
  • Dynex Master
  • 19,396 Answers
Try first unplugging TV for one hour or so, this will reset the unit even if may not solve the problem.
You can check the cable at the back and eventually try a replacement cable, but I do not think it will make any difference.
If half of the screen has lost one or more RGB channels , this is due to a bad lcd ribbon cable, a bad lcd controller board, or a faulty lcd panel.
Parts are available at Replacement Parts: Plasma TVs, LCD
Posted on Apr 20, 2009
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Yea so half of the screen on my Dynex lLCD TV is pink and red, and I have no idea why, any suggestions as to how to fix it?
faulty screen driver lost is color codes. replace its on the back of the screen at the top.
Sep 21, 2013 | Dynex DX-LCD32-09 LCD TV
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Half the screen doesn't work. It goes black sometimes, and sometimes that same half, the right side, has vertical color lines. The tv is only 6 months old. The problem actually went away for a while...
You need to go into the back of set and look for the wire connection to the board that is top center (looking from the back of the set). The wire plug will be about 1 and a half to 2 inches wide with several wires on it. Carefully unplug the wire going to that board and take a pencil eraser and clean the contacts gently and carefully. Plug it back up. The wire mentioned will come from the main board (with all the jacks and connections).
Jun 23, 2011 | Dynex DX-LCD37 TV
I have a Dynex 32"
Take the back off of your set and look for 1 or 2 cables that run from your main board ( the one with all the inputs ) to the TCon board. It is the board on the top of the set. Pull the cable or cables out and put them back in. Make sure they are in straight and tight. Do this on both ends and make sure the TV is unplugged. When the cables are back in, plug in the set and see if the problem is resolved. If not, then your TCon board is most likely at fault.
Apr 19, 2011 | Dynex DX-LCD32-09 LCD TV
Dynex 32 lcd hdtv L32-10C color is flashing green and purple
Just go to the service center where you bought that tv ,cause its ,one year warranty period. just consult your tv to the costomer service personel.
Jun 28, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Vertical lines half way across screen.
Try performing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Norcent LT-3222 32" LCD HDTV SCREEN TURNS GREEN
I have the same problem and need help. Have this TV over 5 years and don't know what to do this it
Aug 29, 2008 | Norcent Technologies LT-3222 32 in. LCD...
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
196 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
