Question about Sharp AR-157E Copier
I was trying to make a copy and by accident I pushed too many copies and when the machine was trying to make that many copies I hit clear and now it won't make a copy.
    Sniper:
  • 67 Answers
Your clear key may be stuck down, try pressing it again to free it up.
Good luck
Posted on Apr 21, 2009
How do you clear error code E000075-0103
Your problem is the ITB. The transfer belt is not centered. It is sliding toward the front of the machine and hitting a sensor there. If you pull the ITB you will see a small pivot sensor that the belt is pushing back. This system prevents the belt from running off the edge and destroying itself. What is wrong is that something is allowing more tension on the back side of the belt and it moves forward. I have found broken plastic pieces in the ITB unit that release the tension on the back side of the unit. Unfortunately, I don't think the plastic pieces are available so you need to change the ITB. That should solve your problem.
May 15, 2012 | Office Equipment & Supplies
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
E studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Apr 13, 2009 | Toshiba Estudio 200L Copier
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
False jam indicator
I had almost the same problem but the problem that I had was that after running 5 or more copies it would show a jam with no paper anywhere. And the only way to clear the jam was shutting the machine off and turing it back on.
What I found out was that the gate (flag) on the fuser unit was heating up and the gate (flag) was sticking a bit. (Plastic that close to the fuser isn't the best design)
Anyway, the only way to resolve this problem was replacing the fuser that had a new gate (flag) already installed.
You can replace the flag by itself also.
The way to see if your machine has the same problem, is if you get a jam and you open the right side door, push the black gate and see if it moves a little bit. If it was stuck then your machine is doing the same as mine was.
Good luck.
Hope this helps.
Mac
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Sharp AR-157E Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
