Question about Dell Axim X3i (400 MHz) Pocket PC
Dell axim x3i problem
My Dell axim X3i stant but stop in Dell stage Send me solution to [email protected] Espanol: My Del Axim X3i prende pero se queda en la etapa Dell.
  • Miguelyedda Sep 21, 2007
    My Dell Axsim X3i starts but stop in Dell stage.
  • 3 Answers
Press and hold the reset on the back and press and hold the power button. This will reset to manufacturing settings.
Posted on Sep 23, 2007
SOURCE:
Backup battery
its in the back of device a slight curved flap is given just lift that flap and its there.
Sep 18, 2008 | Dell Axim X30 Pocket PC
Tip
Dell Axim X3 / X3i / X30 Hard reset
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button.
on Mar 10, 2010 | Cell Phones
Yo tengo Necesidad de ubicar el sensor de los golpes en mi 1994 Isuzu el vehiculo prende pero cuando calienta prende la luz de check engine y despues no prende hay que esperar que se enfrie para prende...
El sensor de detonaci?n se encuentra en el colector de admisi?n en el lado del pasajero. Que los tornillos en el bloque justo debajo de la cabeza. ver http://www.myisuzuparts.com
Aug 02, 2011 | 1994 Isuzu Trooper
My dell axim x30 backup battery needs replacing. Is this something I can do myself?
i believe if you are a bit of a hands on type of person you should be able to do this yourself.
but not without researching !
read this page, should tell you everything you need to know, from the perspective of someone who had to do the same changing of the CMOS battery.
http://www.mobilitysite.com/boards/x3-x3i-hardware-troubles/96005-x3-backup-battery-revealed.html
or read below:
quoted from: Tenc hi4U
DISCLAIMER : I take no responsibility for any damage you may cause to your Axim. The parts and proecedures described in this guide refelct my own experience with my own Backup Battery (BuB) in my girlfriend's Axim X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble Axim X3 with small jeweler's phillips head screqwdriver. Be sure to plave all parts in a plastic bag or other container (4 scres rear cover, 2 screws near port). Disconnect the ribbon connector towards the bottom of the PCB and the speaker wire (also on the lower portion of the PCB). Backup battery should be the green covered circular item under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use strong needlenose pliers to grip and "roll" the leads off of BuB.Be very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder this battery, heat will lead to BuB damage and destroy lead connection to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to respective side (red lead goes to +, black lead goes to -). Secure connections with some type of clamp (I used a binder style paper clip, but a wooden close pin or something else that will hold the leads to the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut to the shape of the BuB. Covering WILL have to be form fitting to fit back into Axim BuB "slot".
6. Reassemble and charge Axim and charge.
Sep 07, 2009 | Dell Axim X30 Pocket PC
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Storage card problems
If it was removed whilst in use, the FAT will have been damaged and it will need initialising and formatting again.
Nov 02, 2017 | Dell Axim X3i (400 MHz) Pocket PC
Windows Media Files
there is a window open some place that is using that file. sometime if you reboot then you can delet it
May 30, 2017 | Dell Axim X3i (400 MHz) Pocket PC
Open Questions:
See all Dell Axim X3i (400 MHz) Pocket PC Questions
Dell Axim X3i (400 MHz) Pocket PC Logo
177 people viewed this question
Ekse
Clive
Clive
