My computer keeps beeping i have replaced the RAM and it still has a steady beep
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Re seat the ram modules......you maybe have to re seat them more that once......the operating system can not see them...It happen to me after a new motherboard install try it several times.... what happen then?
mtg
Posted on Apr 21, 2009
Iturn on my desktop and it just keeps beeping nothing on monitor?
Pull your ram sticks out, leaving only one in place (doesn't matter which spot it's in). If beeping stops and computer boots, you found it. Continue replacing ram sticks until beep returns, and you've found the bad stick.
On the suspect ram stick, try this. Take the eraser side of a pencil, and work the eraser up/down, back/forth on the gold contacts of the ram. What you're trying to do is to clean the contacts with the eraser (stop laughing, it works!).
Try that ram again, if the beeping stops you've saved a ram stick. If not, I'm afraid it's shot.
Best,
Lower
Apr 14, 2016 | HP Computers & Internet
Laptop computer will not power up. using power cord and keeps beeping three times every time when powering up.cleaned ram contacts and reseated these. still no change!
Suggest Anti-Static Procedures need to be followed, laptop opened up, and cooling system cleaned.
Also suggest replacing Thermal Paste on Processor, and Thermal Pad on graphics chipset. (Piece of small copper sheet would be better)
What is the Dell's model name and model number?
Bottom of laptop.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Dell Studio Computers & Internet
IBM Thinkpad R31 1.13GHz Keeps beeping a steady beep when i first turn it on
Step 1:
The memory of your computer was cannot support the system that you load. Just upgrade the memory or else replace of higher memory.
Step 2:
Just load operating system that your used previously. Because that was the compatible system that they used.
Apr 05, 2013 | IBM ThinkPad R31 2657 Notebook
Steady beeps on phoneix bios ecs board
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Jun 19, 2012 | ECS RS400-A (V1.0) Motherboard
Steady continuous beeps & computer doesnt boot..?
Its mostly an RAM problem, you need to check you PC RAM. Also use a sytem utility software RegInOut to optimize your PC. RegInOut is a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of Internet Optimizer enhance users web browsing experience.
Dec 15, 2011 | Lenovo 3000 J205 PC Desktop
The Hard Drive keeps making a bleeping noise and it is not letting me acces it, what could the possible problem be?
you need to know computer BIOS to know message from beeping code. when u know the BIOS product then listen the beep (short or long, how many beep, etc). after u recognize the beep pattern, try to 'google' it with your BIOS product and beep status. or u can reply from this answer, maybe i can help.
tips: a lot of problem that computer cannot run and makes beep sound is that RAM not correctly installed, try remove it and put it in again in another RAM slot. if u use external VGA, try to remove it and put it in again.
hope this useful, regards.
Aug 16, 2011 | Computers & Internet
Having installed this motherboard in the case and connected up I get a series of fast beeps a few seconds after power-up. I have immediately powered down. What is causing this problem? There is nothing in...
In your case, it is a memory problem. It's either one of your RAM has problem if you have 2 slot RAM. Please ensure that you have the right RAM for your board. You can also clean the contacts of your RAM by using eraser.
Below are the most common beep code that being adopted to most BIOS for reporting.
  • short beep - Normal POST(system is OK)
  • Steady short beeps - power supply problem
  • long continuous beep - memory failure
  • Steady long beeps - power supply problem
  • 1 long, 2 short beeps - video card problem
Apr 06, 2011 | Gigabyte GA-G41M-Combo Motherboard
Won't boot, has a steady beep sound.
Beep codes denote that there may be problem with your RAM modules inside your computer Cabinet. Remove the cabinet, remove the RAM modules from the slot, clean the dust particles present and replace the RAM back to the slot properly and try restarting your system. Try 5 continuous attempts like this and at any one your system may come alive. The Beep codes may vary among different motherboard vendors. So refer to your system motherboard manual and there the interpretation for different kinds of beep code will be provided.
I hope this is helpful and solves your problem,
Thanks
Feb 20, 2010 | HP Pavilion m7480n (882780389410) PC...
Satelite L505 powers up then steady beep/won't
Remove and re-seat the memory (RAM) modules.
The task is non-destructive / harmless.
Sep 28, 2009 | Toshiba Satelite A135-S2286 Notebook
Tower Beeping
As I can see the problem is not monitor but your PC if computer chasis beeping, depends on number of beeps the problem can be VGA card one long beep and 3 short or RAM if it beeping one by one short beep and finaly CPU if it continuosly beeps like police sirene. If beeps are pointing to VGA or RAM you must open computer chasis and plug out VGA and RAM and clean dust out of slots and of VGA card and RAM as well with painbrush and vacum cleaner and plug them back.
Dec 12, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
