My DVD RW is no longer detected by Windows and I can't seem to be able to reinstall it. There was a warning in Device Manager under SCSI and RAID controllers and Windows help suggested I uninstall and reinstall it which I did. Except for the reinstall bit. I can't seem to find where to add a DVD drive in Add Hardware. Is there such an option? The tray opens and closes ok so I thought maybe the IDE cable had come loose somehow but I opened up the case and it was fine. The jumper was set to master but the slave IDE plug was in, so I set the jumper to CS (cable select) but that didn't seem to fix it. Any ideas?
Comments:
Sep 21, 2007
- That's part of the problem, my DVD drive isn't in device manager and DVD drive isn't an option under Add New Hardware. I'll try changing the cable to master and let you know how it goes.
Sep 22, 2007
- Looks like the drive is busted
Sep 24, 2007
- Turned my PC on this morning and it's there again. Very odd. If it disappears again I'll try Daniel's solution, if that doesn't work have to get a new one.
1)[while computer is off and power plug disconnected] physically take the ide\cd cable off the dvd.turn cpu on and reboot.Uninstall dvd in ADD\REMOVE DRIVERS [control panel]REBOOT! 2)turn cpu off\unplug NOW:: switch ide cables:master\slave[1] with master\slave[2] connecting any h/d, dvd,etc that you disconnected. turn cpu on and see if computer[cpu] will 'see' your dvd and install the universal drivers. p.s. sometines in unpluging\unpluging,PULLING ide\dvd cable by the 'wires' you damage the connector.
the scsi and raid refers to sata hard drives or ide in a raid configuration.
the dvd drive if on a cable on its own should be set at master, if on a cable with another drive then set it at slave, cable select doesnt always work as the motherboard cannot identify the ide source.
Youe DVD drive will be listed in device manager under cd/dvd drives, click the + sign and if it's listed there, right click it and select uninstall.
Restart the pc and see if it's reinstalled automatically, it should do, then be ready for use, if you still cannot see it in my computer check the drives ide cable and swap the drives over if necassary, if still not showing the drive needs to be replaced.
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD...
(More)
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD BURNER.I have looked ever where and can not fine one because it is a older camera they dont make them anymore. And the new ones do not work on the older one. So if there is anybody out there how would like to sell me one please help me out. thank you. kerrie.
my dvd drive isnt reading original dvdsit reads them for the first time but after a few days it does...
(More)
my dvd drive isnt reading original dvdsit reads them for the first time but after a few days it does not read it there are no problems with the disk as i have checked them on my neighbours pc
