Question about Maytag Dryers
Need wiring instructions to install a 4 prong wire from a 3 prong wire
Maytag model number lde612 and installation instructions changing 3 prong wire to a 4 prong wire
  • 10,865 Answers
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Dryers Logo
290 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
