Question about HP Computers & Internet
My laptop (hp pavilion) is not working at all. the sceen, the lights everything is dead not woking. What should i do to fixed my laptop?
  • Ryan Stiers
    Ryan Stiers May 11, 2010
    Is it not powering up from the battery? Have you tried turning the laptop on with the AC Adapter plugged into the wall?
Hp pavilion dv4 laptop display works with external display only
Switch the display to the laptops screen. Shine a flash light on the screen and look very carefully for a faint image of what should be displayed. If you see it then either the back light or inverter board is dead. Usually the inverter board. These are housed inside the lid usually runnung alone the bottom of the display. If there is no image then the display is bad. The easiest fix would be to remove the entire lid and replace the whole thing. This will effectively replace all three parts I mentioned, but will be more expensive.
Dec 15, 2012 | Computers & Internet
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I have a hp pavilion dv9000 laptop and it wont even turn
If you tried it witht he adapter then sounds like the motherboard is dead.
May 17, 2009 | HP Pavilion dv9000t Notebook
My hp dv7 wont turn on
Its seems like the battery, connect it directly to power, let me know if it works
Mar 25, 2009 | HP Pavilion dv7-1132nr Notebook PC
No power HP laptop
Sounds like the unit's power supply may have failed you will probably need to take it to a repair center.
Jan 07, 2009 | HP Pavilion dv1000 Notebook
Laptop screen
When you see your screen pixelized, it may be a hardware issue, but before concluding it as a hardware related, I request you to try downloading and installing the latest video driver software and if you wish you can even update your computer with latest BIOS update from the concerned website.
After installation, please restart the computer as the changes made will be updated once you restart the computer.
If the issue persists even after installation of BIOS update and Display driver software for your computer, now it can be concluded that the issue is hardware related and your screen has to be replaced with a new one.
Thanks,
Sharath
Jan 02, 2009 | HP Pavilion dv6000z Notebook
My HP pavilion ZE4300 won't turn on
tis is just an idea try it
unscrew the screws behind the laptop
remove the ram clean it wit soft cloth then put it back
also remove the hard disk and plug it back
tis worked for me once
but if u dont no how to do it ask someone who can
Dec 12, 2008 | HP Pavilion ze4300 Notebook
Hp pavilion dv9005us NO sound problem
you may want to check to see if the speaker wire is connected to the audio board. You'll need to remove the Keyboard, palm rest, etc. It should be located toward the front of the LT.
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
