Question about BenQ MP610 Multimedia Projector
Projector Image Problem
When trying to watch a DVD through my projector from the DVD player, the image projected on the wall is small and narrow. It is wider than the normal TV image but much narrower. I get the full image when I watch it through a laptop but not the T.V or D.V.D
  • 563 Answers
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Posted on Apr 21, 2008
SOURCE:
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
Image being projected is VERY large unless you have the lcd 1-2 feet in front of screen.
That's the design of the projector -- some are designed to be "narrow", such as the projector in the back of a movie theatre, and some are designed to be "wide", like a teacher standing at the front of a small classroom, placing the projector a few feet away from the projection-screen.
Buy a different projector that suits the dimensions of your room.
Mar 09, 2011 | Computers & Internet
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
I am using a Sharp LCD projector XG-E1000UB. I do not have a manual...how do i project a smaller image..the image from the DVD player is huge..i want to project it on a screen in my backyard...
Although you can change the image size +- 10% from the projector ring, if you need to reduce the size significantly you will need to the reduce the throw of the image by moving he projector closer to the sreen.
Aug 15, 2009 | Electronics - Others
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Won't project DVD playing in a PC laptop
My first thought, based on what you said, is for you to check the resolution being sent to the projector...if it's too high,(above the projector's ability to display it) you'll get a distorted or even a blacked-out display. Also, check the settings for the program which is running the DVD. There could easily be an option set incorrectly.
Nov 12, 2008 | NEC MultiSync VT440 Multimedia Projector
Getting image to project
You are going to have to read the manual, and operate the projector as you read each section
Oct 16, 2007 | Sony VPL CS2 Multimedia Projector
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
BenQ MP610 Multimedia Projector Logo
221 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
